Rear Diff Recall
According to http://www-odi.nhtsa.dot.gov/owners/...000&refurl=rss
2009-2012 Ram 1500 manufactured:
2/27/2008 => 6/30/2009
12/1/2009 => 10/20/2011
2009-2011 Dodge Dakota manufactured:
2/27/2007 => 6/30/2009
12/1/2009 => 9/30/2011
2009 Chrysler Aspen manufactured:
1/3/2008 => 12/18/2008
2009 Dodge Durango manufactured:
Report Receipt Date: FEB 06, 2013
NHTSA Campaign Number: 13V038000
Component(s): POWER TRAIN
Potential Number of Units Affected: 278,222
Manufacturer: Chrysler Group LLC
SUMMARY:
Chrysler is recalling certain model year 2009-2012 Ram 1500 trucks manufactured from February 27, 2008, through June 30, 2009, and from December 1, 2009, through October 20, 2011; model year 2009-2011 Dodge Dakota trucks manufactured from February 27, 2007, through June 30, 2009, and from December 1, 2009, through September 30, 2011; model year 2009 Chrysler Aspen trucks manufactured from January 3, 2008, through December 18, 2008; and model year 2009 Dodge Durango trucks manufactured from January 3, 2008, through December 18, 2008. The rear axle pinion nut may loosen due to a omission of an adhesive patch.
CONSEQUENCE:
If the rear axle pinion nut loosens, the axle can lock up and cause a loss of vehicle control and/or a vehicle crash with little warning.
REMEDY:
Chrysler will notify owners, and dealers will install a pinion nut retainer, free of charge. The recall is expected to begin during March 2013. Owners may contact Chrysler at 1-800-247-9753.
NOTES:
This campaign is an expansion of a recall campaign 12V-474. Chrysler's recall campaign number is N08. Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
SUMMARY:
CONSEQUENCE:
REMEDY:
NOTES:
If you get a recall notice you need to bring it in when the parts are available.
Transport Canada Recalls
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/...chResult&pg=-1
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/...&ft=&ls=0&sy=0
SUMMARY:
CONSEQUENCE:
REMEDY:
NOTES:
SUMMARY:
CONSEQUENCE:
REMEDY:
NOTES:
The dates of build on the Dakota's are wrong. It's states 09-11 with a build date starting in February of 2007. This is a typo and should state 2008. This is being corrected on the official documents.
Could this be why my 2011 rear end kinda sounds weird...or I think it is the rear end. at 70 mph and slow down I get a high frequency growl and it doesn't sound like tires...maybe the sound of wheel bearing going out???, but only 10k on the odo.
It could be but no way to tell for sure without having it checked out. If you even think this could be the issue you are experiencing I would suggest a appointment with the dealer as soon as possible.
I am having issues with my 2007 Ram 2500 rear differential. The Race Bearing went bad and now my mechanic says to replace the entire differential ($2,000 later). What can I do about this? My truck only has 74,000 miles on it! I've only towed a 5th wheel trailer about 15,000 at the most! Why did it go bad! Will Dodge do anything to fix it?
