4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I had a ticking noise. At first only at cold starts. Then it got worst. Took to dealer, the problem was broken bolts on exhaust manifold. $500 labor. $600 total
That's the first thing they usually check because the bolts are known to break on the Rams around 50k miles or so. The issue with mine was no that manifold but something more serious that they couldn't find. They ended up buying the truck back from me.
Following this thread cause I have the same problem. Hopefully someone with hands on experience with the timing tensioner and guides will see this and speak up. From what I've researched it seems whats happening is the timing chain guide/tensioner wear down to the point that it will drive fine on 8 cylinders but as soon as the timing adjusts to get into 4 cylinder mode (MDS) it gives the timing chain just enough slack to slap against something in there causing this rattle noise. As soon as I get my backup vehicle going I will be tearing my hemi apart to fiqure this out once and for all.
-2010 ram 1500 SLT 5.7 hemi 4x4 122k miles all stock.
For the past few months my 2009 RAM had a ticking sound not unlike when we were kids and put cards in our bicycle spokes. ONLY did it on coast down or when the engine was unloaded and MDS on. It got louder and louder so I took it in and they replaced a bent pushrod on an intake valve. The (MDS) lifter for that pushrod had a "failed latch" whatever that is. It is my opinion the failed lifter caused the bent pushrod. They put it all back together and STILL had that sound, they replaced all MDS lifters and then it finally went away. I looked on the internet and found that bad MDS lifters are NOT uncommon to the 5.7L Hemi.
I dealt with this problem for four months last year. 2011 ram Five different visits to the dealership and ended up being the same as your 2009 issue. Lifter broken pushrod they replaced one head all of the M DS it fixed the problem temporarily. Problem is back 6 months later. Exact copy of the ticking you all are mentioning. Chrysler and especially the dealerships act like they've never heard of this problem. It's embarrassing to drive around town at slow speeds. Tow haul off does stop it.
Greatly appreciate the update. While doing my research I discovered that just under 40 camshafts were being used monthly per month for 2009-2010 5.7 Hemi Rams nationally. Because camshafts are rarely an issue on Chrysler products, this made me very suspicious. Since this problem appears to affect only a small portion of the 5.7 truck motors, I'm thinking that at some point they had a hardening issue which was not readily detected. I've not heard of this symptom occurring on 2011-2014s, and not on cars at all.
The reference to "soft" lifters may relate to the spring inside the lifter body.
Best regards,
Dusty 2014 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 008900 miles.
I have a 2011 Hemi with the same issue. Several trips to dealer Replaced 1 head lifters broken push rod all MDSs fixed the problem for 6 months. Now it's back. I'm glad to see others are reporting this as last year nobody was recording issues. Time to head back to the dealer again.
This Hemi has the MDS tick subsequent to the damage (2012) depicted. It's not a timing chain issue! Chrysler (FCA) flipped me off just prior to the power train warranty expiration because... "It's normal." Horse puckies, it's normal.
Reason: Add related content
Ok so since the nice weather has hit ( atleast in the Maritimes Canada ) . It's a pis off not being able to put window in truck cause of this noise. It was briefly mentioned above about Chrysler never hearing about this before. I'm in the same boat! When I reached Chrysler Canada they pretty much did what I already did, which was notify the dealer. So really no help at all other than the case being recorded. After almost three years I still have this issue and can't fathom for the life of me that if anyone from the dealer or Chrysler itself had my truck they would think this is reasonable . Question! Has everyone here sarted a case or pitched a call to chrysler? Cause I'm starting to think they know of a lot more complaints than they are letting on about. Like any recall this has to be sorted. I
Love this forum! It's helpful and I guess in a way nice to see im not alone! But it's not right for us to pay X amount of dollars and warranty and get that type service and answers regarding this issues. This obviously seems to be on both sides of the border within Canada and the U.S. So have we all put in a work ticket? Complaint? To Chrysler? I'm calling again and having numbers may go a different route with guys. This time there better not be any " never heard of it before" thanks everyone.
Good pictures. Based on the imbedded marks (possibly from a screw or bolt or a piston fragment) it looks to me that something got into the combustion chamber causing the damage. So I'm not sure this was even related to the MDS noise, much less proving or disproving a loose timing chain theory.
Ticking noise: Chrysler does know but some dealers may not
I believe Chrysler is aware but also believe at least as of the fall of 2014 do not know how to completely resolve this problem.
After my fiasco last summer which include about 3 months of pushing the dealer and many many parts thrown at it because they didn't know how to resolve the problem. Ill be going to the dealer again next Monday to see what they say this time. Chrysler was involved last summer and the case was closed in the fall but only after I got an extended warranty from them paid for by them because I had a feeling the problem was not fixed and the issue would come back, as it did. I called Chrysler again before I called the dealer to ensure we don't start over from scratch. Now my info is linked to the issues I had last fall. Ticking.
Will keep you all posted.
How many miles were on this motor?
55K km. Damage was caused by a screw with 10mm head - similar to the one used to fasten the TB to the manifold. Theory (dealer's) was that the screw was somehow left in the intake manifold during manufacture. The screw had been in there for some time - the inner walls of the plenum were scored up bad. The engine was purring like a kitten when I approached the dealer about an oil leak on the intake near the PCV valve housing. Shortly thereafter, the internal damage was discovered. MDS ticking began shortly after this repair. It took me over a year to get somebody at the dealer to acknowledge that. They agreed that it was not right. Chrysler engineering disagreed.
