Dodge Ripp Supercharger report and experience
Old May 29, 2013 | 08:20 PM
wwillf01's Avatar
wwillf01
Default Dodge Ripp Supercharger report and experience
So I took the plunge on the Ripp supercharger... I wanted to let everyone to know my experience.
I had it installed by one of their recommended shops.
Either I had an intake manifold leak (I have 46000 miles) or one was created by the supercharger honestly I don't know. That was the first thing I repaired.
I am now two weeks into it and trying to get the tune worked out.... (Truck drivable) It does take a while to get the tunes back so be prepared to wait if there is a problem.
Currently I get rich readings along with intake manifold warning (This one is a big issue because you have to pull over to the side of the road...) The shop has ran a smoke machine through the engine to determine there are no air leaks...
I am going into the third day waiting for the revised tune..... We will see. I will update everyone as this plays out
For now I will enjoy my rental a turbo charged Ford Fiesta
Old May 30, 2013 | 12:33 PM
KDubya's Avatar
KDubya
I've been looking at the RIPP for my 2009 1500 so I'm interested to hear how this plays out for you.
A question if you dont mind, what made you choose the RIPP?
Thanks and good luck!
KDubya
Old May 30, 2013 | 05:00 PM
wwillf01's Avatar
wwillf01
KDubya
So now Ripp is telling me the tune is fine and swap the spark plugs for a warmer set...... I don't see how that would turn the p107 manifold warning on but we will see... the existing ones were pretty black....
I choose ripp because it looked like they had a well thought out product and I have a 2011.
Old May 31, 2013 | 03:20 PM
LU229's Avatar
LU229
Good Luck...!!! I sure hope it all works out and it dosent smoke your engine for you.
Sorry but rotflmao = furd turbo flea esta`s.
Old May 31, 2013 | 03:22 PM
LU229's Avatar
LU229
I agree, i dont see how thats going to fix your actual problem, BUT who knows, we`ll find out though huhhh.
Old May 31, 2013 | 07:59 PM
POWER SEDAN's Avatar
POWER SEDAN
Did you try cleaning the MAP sensor. Black plugs, must be running really rich!
Old Jun 3, 2013 | 10:15 PM
wwillf01's Avatar
wwillf01
So we put some new plugs in that run a little hotter... Seemed to help... It runs better but still am getting two rich errors after logging a few hundred miles... So I sent off the log for hopefully a third revision on the tune.... map sensor was clean... So the saga continues
Old Jun 5, 2013 | 05:11 PM
stlram's Avatar
stlram
Default Stupid question but?
What made you go with a Ripp supercharger anyway? These trucks dont have much tolerance for boost so why not use a reputable company? Eddlebrock and ProCharger make great systems for these trucks and they are basically plug and play.
Old Jun 5, 2013 | 05:12 PM
wwillf01's Avatar
wwillf01
Theu did not have one for a 2011 after I ordered it magnason added my model since
Old Jun 5, 2013 | 05:41 PM
wwillf01's Avatar
wwillf01
also I was told these units were plug in play. They have them running on a 2000 trucks. I think the problem is with the ECU in the 2011. We will see I'm waiting for the third revision on the tune.
