Can we read the check engine codes without a code scanner on a 2012 Ram 2500?
Old Aug 12, 2015 | 04:24 PM
TrailBlogger's Avatar
TrailBlogger
Default Can we read the check engine codes without a code scanner on a 2012 Ram 2500?
So I just bought a used 2012 Dodge Ram 2500 (2WD, Auto, 5.7L) from a local Dodge dealer the day before yesterday. I had the truck home for ONE DAY and the check engine light came on. Just took a casual drive to pickup a pizza last night and when I got back in to drive home with my pizza I noticed my check engine light was on.
The truck is at 75,000 miles and shows a little over 2000 hours on the engine. It did not seem to be running weird or anything on the ride home. Oil looks like new and air filter looked new as well. Checked my radiator fluid and I saw some chunks of gel in the cap area so wondering if a coolant line might have gotten clogged up or fluid just needs to be changed. Could that throw a code?
I had seen before on the older Dodges that you can check your engine codes using the console in the cab with no scanner/code reader thing. Is that possible on the newer trucks like my 2012. Any suggestions? I am all ears here. I love the truck but this is pretty concerning to have it throw a code the very first day.
Old Aug 12, 2015 | 08:15 PM
Not sure but you can take it to any auto parts store and they will read it for free. You should buy yourself a code reader. You can get them for less than $20 off amazon. Will be the best tool in your toolbox.
Old Aug 12, 2015 | 09:11 PM
HammerZ71's Avatar
HammerZ71
Just pick up a cheap code reader. Used to use my tuner on my previous trucks/jeeps but now I'm running a stock CTD. Sold the tuner, bought an Autel Maxiscan off Amazon for under $20 to the door. Keep it in the glovebox to read and clear codes...
Old Aug 12, 2015 | 09:43 PM
TrailBlogger
Thanks!
TrailBlogger
Thanks!
Old Aug 12, 2015 | 09:47 PM
TrailBlogger
So the dealer just let me know they have it fixed. Said it was a clogged sensor in the fuel system and it should be all fine now. Glad to hear i am getting it back right away. Just hope this fix is a good long lasting one. Will buy a reader next time it happens. Thanks guys.
Old Aug 13, 2015 | 08:56 AM
HammerZ71's Avatar
HammerZ71
Order the code reader now so the next time you get a CEL you'll know right away. Some CELs you can live with, some you need to stop driving to avoid a larger, costly problem. If you can't read the code you won't know.
It's also cheap insurance from getting scammed. Example: Being told you need new Cats at the tune of about $1200 parts and labor when the problem is a $30 sensor...
Old Aug 13, 2015 | 11:53 AM
DodgeCares's Avatar
DodgeCares
Thanks for following through with an update! I'm happy to hear they got it taken care of quickly for you.
Old Aug 16, 2015 | 10:02 AM
oldjeep's Avatar
oldjeep
Yup, this is what I use along with an app on my phone:
Amazon.com : Professional Diagnostic Tool OBD2 OBD-II ELM327 ELM 327 V1.5 Bluetooth Car Diagnostic Interface Scanner Works On Android : Automotive Electronic Security Products : Car Electronics Amazon.com : Professional Diagnostic Tool OBD2 OBD-II ELM327 ELM 327 V1.5 Bluetooth Car Diagnostic Interface Scanner Works On Android : Automotive Electronic Security Products : Car Electronics
App for phone, laptops, etc
http://www.obdautodoctor.com/
Old Aug 26, 2015 | 02:11 PM
TrailBlogger
Thank you. I will check that out.
