Dodge Cares, Why are the manifold bolts breaking?
Old Jun 1, 2020 | 01:09 PM
  #91
tigo2018's Avatar
tigo2018
Hello,
This is a great info Daof4 knowing that alot of heat is a part of the problem here,I'd say let's experiment differents solutions because we are almost left alone with this.
I did the passenger side a few months ago,I installed springs between the BBK and the exhaust,it might help the rear bolts on those rear cylinders to support torsion,also,this is a big and heavy exhaust line.
Will change the driver side soon and do the same but before I'd like to check on temperatures with a infra tool before the cats just to see if I'm able to notice a difference,it will not be while in charge on the engine but at different RPM,just experimenting for fun .
Old Aug 4, 2020 | 04:53 AM
  #92
13Durango's Avatar
13Durango
Default Exhaust Manifold leak
Originally Posted by Pedro Dog
As I mentioned, the back cylinders run extra hot on the hemi. The other manufacturers probably do a better job at cooling the back cylinders. The bolts mostly snap at the head leaving a stub to grab when the manifold is removed.
Any idea if a broken exhaust manifold or its bolts may affect the performance of the Hemi, Sir, please?
Old Aug 4, 2020 | 06:58 AM
  #93
If you have a leak, yeah, that can have an effect.
Old Aug 5, 2020 | 06:55 AM
  #94
Netsurfer S's Avatar
Netsurfer S
I think the easiest way to fix this problem is to buy stainless steel headers. The original cast iron retains the heat more and expands differently than the other metals. Why Chrysler did not think of this is beyond me!
Old Dec 5, 2020 | 04:55 PM
  #95
Crabman's Avatar
Crabman
Netsurfer, did you try a set of headers?
Old Apr 29, 2021 | 06:21 PM
  #96
Dr. Bill's Avatar
Dr. Bill
My 2009 Ram 1500 Hemi has had its exhaust manifold bolts replaced FOUR times. Has this issue been resolved? My son just bought a used 2017 Ram 1500 Hemi and I was wondering if this will be a problem with his truck. I have life time warranty, but he does't.
Old Oct 4, 2021 | 05:39 PM
  #97
harryjoe's Avatar
harryjoe
Is there any help from dodge for these if they are past the warranty period? I already fixed the passenger side. Its a lot more than their simple fix when the bolt is broken flush with the cylinder head.
Old Oct 4, 2021 | 08:03 PM
  #98
There is no recall on them, so, if you are beyond the warranty period, likely dodge isn't gonna help. Best fix for them is shorty headers, and good quality header bolts/gaskets.
Old Oct 10, 2021 | 09:34 AM
  #99
GumbyRT's Avatar
GumbyRT
I appreciate how you’ve been playing this harp through almost the entire thread - I just finished reading through it. I agree that the manifolds are the problem.
I’ve seen my share of Hemi’s in the shop and what’s been clear to me is the manifolds have a warping issue which is causing the bolts to stretch and break, and instead of replacing the manifolds, Dodge attempted to remedy the problem with different bolts. The problem is once the manifold is warped it has to be planed or replaced, otherwise it’s just going to keep pulling/stretching and the bolt will stretch and break again.
I’m not an engineer but I also don’t condemn them for the fault either. Chances are good at least one engineer attempted to remedy the problem and was shut down by someone above them.
There are so many factors to consider when building a vehicle and the engineers are only one step in the process - they are not the buck-stoppers with the final say on everything. Like many of us on these boards, they’re just trying to do their job within the limits given them by their employer.
Old Oct 10, 2021 | 11:22 AM
  #100
It's likely one of those flaws that the computer models couldn't predict, and only real world testing would find. Of course, the real world testing was in the hands of those that bought the trucks...... I don't fault the engineers, for the reasons you state. I fault dodge for not addressing the problem once it became known. Of course, that would have been money out of their pocket..... and they did do a fair number of repairs under warranty.... which likely clued them in to the problem.... They just didn't feel the need to SOLVE the issue. Just slap a band-aid on it, and call it day. After all, it isn't a 'safety' issue......
