Is it a bad idea to downgrade from a 5.7 to a 4.7?
4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
So I currently have a 2014 2wd ram 1500 quad cab with the 5.7, and 8 speed transmission. I am considering trading in my truck for a 2010 4wd Dodge Ram 1500 crew cab with the 4.7 and I believe 5 speed. I’ve previously had a 3rd gen 4.7 and although it was slow It could tow pretty well. I just need advice so I don’t make a dumb decision, but the truck I’m considering has 140,xxx miles and my current has 130,xxx
All the trucks have pro's and con's. You need to figure what works for you. The 4.7 does come with a 545RFE transmission and maybe 9.25 rear axle. Maybe with LSD. I would check with any service records and see how it looks. Good luck. Leonard
The 5.7 is a far better in almost every way and fuel mileage is about the same between the two. You couldn't give me a truck with the 4.7, they are junk motors in my experience.
I wouldn't go to a 4.7L myself. The newer 5.7 hemi 3.92 gears works pretty decent and is decent of fuel mileage. My 2021 5.7 ram gets 12-13 L/100km, my 2016 ram 5.7 ram get 13-14 l/100km. Has more power than the gm 5.3L, so you can tow and haul more
