truck is dead
Old Feb 26, 2023 | 06:52 PM
artprice's Avatar
artprice
Default truck is dead
While siting in my 2013 1500 it suddenly died. It was idling and stopped running as if someone had turned it off. Now it will not even turn over. I have tried reconnection the wire harness down near the emergency
brake, Have tried resetting the computer. Checked as many connections as possible. Nothing seems to help. Any advice would be appreciated. Thanks
Old Feb 26, 2023 | 09:26 PM
How's the battery?
Old Feb 27, 2023 | 08:49 AM
artprice's Avatar
artprice
How's the battery?
Battery is fine.
Old Feb 27, 2023 | 09:55 AM
Do the lights in the dash come on? Security light??
Old Feb 27, 2023 | 10:52 AM
artprice's Avatar
artprice
No dash lights,but the head lights work. remote door lock works. No security lights are on.
Old Feb 27, 2023 | 11:12 AM
Popped a fuse somewhere, or bad ignition switch? Headlights always have power, regardless of key position.....
Old Feb 27, 2023 | 12:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
If the battery is good. Have you check for any codes? And if you do what are they.
Old Feb 28, 2023 | 09:10 AM
aleekat's Avatar
aleekat
Originally Posted by artprice
Battery is fine.
What's the static voltage?
What's the cranking voltage?
Old Apr 1, 2023 | 04:03 PM
scottyyyy's Avatar
scottyyyy
Have you found the solution?
