Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Kicker 750.1
Old Jun 25, 2007 | 04:50 PM
  #121
rtkota5point9's Avatar
rtkota5point9
Default RE: Kicker 750.1
On the seat bolt subject. People say seat and seatbelt bolts are bad grounding points because those areas are harnened steel. When you temper steel, it loses some of its conductivity in the process. So those areas don't conduct as well as another point might.
But I wouldn't be too worried about it. It's standard practice in most shops and should be sufficiant.
Speaker wire: Oxygen free 14G high strand. Should be perfect for what you need. Stay away from low strand wire. (Which most aren't so don't worry) And don't use anything that has a copper wire on one side, and a tinned (Silver) wire on the other side. Reason is, one conductor will perform different than the other and this isn't necessarily good for the amplifier. It was very common years ago to see that type of wiring. They did it to distinguish the 2 wires for (+) and (-), but ddin't think about the varying charateristics of the 2 conductors. Now adays, you shouldn't come across it anyways.
Old Jun 27, 2007 | 11:35 AM
  #122
Captain Pioneer's Avatar
Captain Pioneer
also if u are running more than one amp... try to ground to the same point in the vehicle so as to avoid ground looping
Old Jun 28, 2007 | 02:00 AM
  #123
cr80renob's Avatar
cr80renob
ORIGINAL: rtkota5point9
Thanks for all the information about speaker wire! That was really well explained! Thanks!
Old Jun 28, 2007 | 02:03 AM
  #124
cr80renob's Avatar
cr80renob
ORIGINAL: Captain Pioneer
I am planning on grounding them to the same place... Thanks for the tip!
This may sound dumb, but what is ground looping?
Thanks,
Shane
Old Jun 28, 2007 | 04:27 AM
  #125
habeba86's Avatar
habeba86
Ground loop is a buzzing noise that you can get by having bad grounds.
Old Jun 28, 2007 | 02:53 PM
  #126
cr80renob's Avatar
cr80renob
ORIGINAL: habeba86
Well then, I will definately make sure I have an awesome ground!
Old Jun 29, 2007 | 11:29 PM
  #127
cr80renob's Avatar
cr80renob
Update!
I got the amp rack carpeted yesterday! It looks awesome!!! Yesterday I also got the subs all wired and mounted in the sub box!
So when I get back in town, all I have to do is mount the amps on the rack, then just plug all the wires in... So I am almost done!!! It wouldn't take as looooong if I was able to stay in town for an extended period of time....
I will get pics up as soon as I get it all finished up!
Old Jun 30, 2007 | 10:22 AM
  #128
rtkota5point9
Good job! Post pics!
Old Jul 3, 2007 | 07:41 PM
  #129
the727kid's Avatar
the727kid
Just for the record a ground loop is where there are multiple grounds in a system and there is different resistances in the system causing the noise. And best spot for a ground, besides directly to the front battery is to drill through the floor board use a grommet and ground directly to the frame of the car.
Old Jul 8, 2007 | 08:35 PM
  #130
cr80renob's Avatar
cr80renob
Alright! So I got back in town today and I got the amps mounted and ran all the wires I could while the amps are out of the truck... Now all I have to do is put the amp rack into the truck and connect the power wire and ground wire! I still have to install the battery and all that, but I see the light at the end of the tunnel! I think it should be all done by Tuesday (But don't hold me to it!) haha!
So all in all, I don't have much work left to do at all! I am sooooo excited to get this put in my truck and just crank it up (of course, after I "break in" the subs)!
