Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Slowly getting it installed.. (pics)
Old 07-02-2007, 03:46 PM
weswing04's Avatar
weswing04
weswing04 is offline
Default Slowly getting it installed.. (pics)
(Copy and paste from another forum)
Vehicle: 2004 Dodge Ram Regular Cab
Premier 800PRS
CDT EF61 + Upstage 500 kit
eD 13Kv.2
Memphis PR100.4 for the tweeters
Soundstream Rubicon 302 for the mids
MTX Thunder 250D to the sub
eDead UE & v1SE + Ensolite
Knukonceptz wiring
Goals: All of my previous stereo systems had mostly good equipment, but always went cheap on one or two things. I have been gathering this stuff since January, looking for good deals here, sounddomain, ebay, etc.. finally got everything in this week and ready for install. I am not going for being the loudest kid on the block or anything. I listen to rock and I want the stereo to have good sound quality all the time. I have always wanted an active front stage, so I will have it in this install. I will lose all space behind my seats, but thats fine. I don't want anything to stand out and look out of place, it needs to look like it belongs there. I HATE harsh tweeters too. /random babbling
On to a few pics:
I can't do much outside, due to Oklahoma becoming a rain forest as of late..
Left Amp Rack
With the amp in it..
Rear..wiring and shtuff goes here
Right Amp Rack
Amps in the rack..
Beginning of the sub box
Lil further
I quit for the night due to mosquitos about to carry me away.
The sub goes behind the center console, with an amp rack on each side. The sub enclosure is a lil larger than the amp racks... It'll make more sense tomorrow when I get it done and post more pics.
I smell like wood now.. yay.
weswing04's Avatar
weswing04
Default RE: Slowly getting it installed.. (pics)
Mock Up
With Carpet... crappy cut around the hole... but it will be covered.
Covering the enclosure face with black vinyl, for a flush sub mount.
Finshed..
Old 07-02-2007, 03:47 PM
weswing04's Avatar
weswing04
Premier 880PRS providing the tunes..
Amp Mounted..
Vinyl face attached
Test Fit in the truck
Two layers of v1SE and one layer of 1/8" ensolite
All clean and ready for eDead UE
TW-25 Tweeter mounted in the kick panel
Driving with no seats.. kinda sucks
weswing04's Avatar
weswing04
Not pretty, but its under the carpet..
Old 07-02-2007, 04:06 PM
rtkota5point9's Avatar
rtkota5point9
rtkota5point9 is offline
Awesome! Keep the pics coming. We LOOOOOOVE pics!
Old 07-02-2007, 09:26 PM
HuntinHanson's Avatar
HuntinHanson
HuntinHanson is offline
wow lots of work put into that system, great start so far!
Old 07-02-2007, 09:57 PM
weswing04's Avatar
weswing04
Almost done, but my memphis amp for the tweeters has problems.. the rca input jacks dont work right, you have to apply pressure on them in odd angles to get it to work. Also, the mtx sub amp doesn't seem to work.. it is getting power and an audio signal, but no output. Trying to troubleshoot now.. sucks
Trending Topics
Old 07-03-2007, 01:11 AM
cr80renob's Avatar
cr80renob
cr80renob is offline
Good luck on the trouble shoot!!!
I was the guy on the ICIX forums that asked you how much Edead sound deadening you put in... I was thinking that 120ftĀ² of v1SEĀ² would work, What do you think?
I only really want to put in the v1SEĀ² and maybe paint on a can of v3.
How easy was it to put the v1SEĀ² in? What was it like to work with?
Old 07-03-2007, 01:37 AM
weswing04's Avatar
weswing04
I think 120 would be okay, depending on what you're wanting to do. I was trying to seal out road noise AND a loud exhaust.. but then again i used a lil of the v1 thin stuff... yeah, 120ft should be fine.
its very easy to work with.. it bends and forms to shapes quite easily. heck even the 120mil UE was easy to worth with.
Old 07-03-2007, 07:36 PM
the727kid's Avatar
the727kid
the727kid is offline
Everything looks real good except the tweeter in the kick, looks like the tweeter is facing directly at your feet. That is going to through off your staging real bad, I would stick with just the tweeter in the a-pillar, it will give you less harshness as well, as you said you don't like. But if your going active I would hope you knew all that .
Quick Reply: Slowly getting it installed.. (pics)
