Remote starter/keyless entry?
![Unhappy](https://dodgeforum.com/forum/images/icons/icon9.gif)
I have a astrostar remote starter/keyless entry and I used it fine and everything worked. Now Everything works on it but the unlock button on the device! It will let the lights flash like it would unlock, but it wont unlock! Everything else works but the unlock button, the starter and lock button all work.
Does anyone know what is going on?
Thanks in advance!
Brendon.
Thanks in advance!
Brendon.
Unlock is still working at the switch? If not, there's a break in the wire and it needs to be reconnected. If the doors still unlock with the door switch, it's either a bad control module or there's a bad connection to the unlock wire. Was the remote starter installed professionally or by you? If it was done at a shop, see what sort of warranty the install shop offers. They should at least be able to take a look at it and tell you what the problem is.
So if the switch still works, and the factory keyless still works, the issue is in the brain unit or a connection to it. Check out the shop's workmanship warranty. If they have a lifetime workmanship warranty, they should be able to at least take a look and isolate the problem. If they don't offer a lifetime warranty and won't take a look at the starter, find a shop that will offer a lifetime warranty and have them pull the bad unit out and replace it with a new one.
Batteries..........those key fobs are in a box and well most work stations as I said before are footprinted so that everything is neat and orderly. What happens is when stock runs low usually someone comes along and dumps a box of keyfobs in the space where they belong but there are still some on the bottom...never get cycled into the system maybe for a couple years since parts changes for those may go years. Anyway so somehow somebody for some reason cycles the parts or digs deep into the box and you get one with a battery already over a year old,not used much but still batteries if not used also die. The reason I say this is because on my 2000 Dakota I had a similar issue while I worked at Chrysler still, anyway I got new batteries and problem solved. You can buy them at the drug store...duracell seem to be the most popular. They say they last about 2 years.Hope this helps.
Oops this wasn't meant to go here but this issue does exist.
Trending Topics
It is going to either be the brain to the keyless entry has a bad unlock output which is basically a relay. Or it is going to be a bad connection of that same output. Dont even worry about the batteries...If the car goes through all the motions during a unlock request (parking lights flash) but just the locks aren't actuating , that has nothing to do with the batteries. If your system starts to get intermittent (sometimes works sometimes doesn't on both lock and unlock)or the range has diminished, that would be a sign of low batteries.
