Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Question about head unit in infinity system
Old 05-03-2005, 02:07 AM
miabanshee's Avatar
miabanshee
miabanshee is offline
Default Question about head unit in infinity system
Alright I have a 2002 Dodge ram quad cab with the 7 speaker (i think) Infinity system. I have a Sony MP3 head unit I wanted to install in place of the stock head unit. Does any one know if this is possible because the wiring harness I found for the head unit is only for 4 speakers. Is there anything I can do to install this head unit?
Old 05-03-2005, 03:45 PM
techmanbd's Avatar
techmanbd
techmanbd is offline
Default RE: Question about head unit in infinity system
Actually with the 7 speaker infinity system, there is an amp in the truck. The 4 speaker output is all you need., It goes to the amp or amps and then it splits the sound to the 7 speakers.
Old 05-03-2005, 06:04 PM
miabanshee's Avatar
miabanshee
Sounds good.... thanks for the reply.
Old 05-03-2005, 11:32 PM
miabanshee's Avatar
miabanshee
OK i put the harness to the sony head unit and plugged it in and I have no sound at all. I do have power to the head unit. But no sound is going to the speakers? Does any one know what the problem could be?
Old 05-04-2005, 12:18 AM
techmanbd's Avatar
techmanbd
One IDea to look into. There is a wire that is blue that is called the power antenna that comes from your head unit, Is it hooked anywhere? if not it needs to feed to the acc line of the amp to turn on the amp.
Old 05-04-2005, 07:03 PM
miabanshee's Avatar
miabanshee
That turned out to be the problem! Works fine now.... last question is why do I have lots of static through the AM/FM channels. I bought the antenna adapter I need but it has lots of static you can barely hear the radio. The cds play fine. Am I not doing something right ? the connection is tight.
Old 05-04-2005, 08:19 PM
techmanbd's Avatar
techmanbd
with the adapter, was just plug and go, or did you have to crimp it on to the antenna cable?
2 things I can think of. Not center pin is not reaching into the adapter. The connection may be tight, but the pin is not touching into the socket.
Or if you had to crimp yourself, make sure that the outer shield of the cable is not touching the center wire
Trending Topics
Old 05-04-2005, 08:45 PM
techmanbd's Avatar
techmanbd
Just thought of a way to find out. Have the stereo on a station you know you should get. take a wire and touch the center pin of the antenna cable and the socket of the stereo and do that at any connection and see if it will come ine, then yuo know it isn't making a solid connection
Old 05-04-2005, 11:57 PM
miabanshee's Avatar
miabanshee
OK thanks for all your help, I'll check it out tomorrow and let you know how it went.
Old 05-12-2005, 08:40 PM
miabanshee's Avatar
miabanshee
OK I found out that the antenna cable that plugs into the inside of the head unit is messed up... its a sony head unit? does any one know where i can find this cable?
Quick Reply: Question about head unit in infinity system
