No foxbox -- next best thing?
$180 does sound like a pretty decent price. other options that I have found.
http://www.topedgeonline.com/Bassfor...p/bf210ram.htm
nice looking box but spendy
http://www.topedgeonline.com/Dodge_Q...0206dgq210.htm
your basic MDF enclosure and a lot cheaper
EDIT*
Found this guy on ebay that says he can do custom fiberglass boxes for under the seat @ $70 per side. May be worth looking into.
http://cgi.ebay.com/ebaymotors/Dodge...o#ht_542wt_939
nateroach
EDIT*
nateroach
The only issue is, the subs i just bought have a suggested size of 1.0-1.5 cu ft (combined for the PAIR). Most fiberglass boxes are like 2 cu. ft. If i understand correctly, having the box too big is just as bad as too small. I'm aiming for a box with 1.2 (each sub suggests .6 cu ft, with a range tolerance of .5-.75). If my assumption is correct, would I be better off getting a complete 3/4" mdf box so its the correct cu ft? Or is there a way to make the fiberglass ones smaller?
Wait, which subs did you buy? I for some reason thought the p3's wanted .75 to 1.25 cu ft per sub... And I was looking it up, the p3's prefer a sealed box over a ported box. Certain subs do better in different types of enclosures, I will post the link.
http://www.rockfordfosgate.com/produ...n_US&p_status=
exactly. I want a sealed box with 1.2 total cu ft. exactly what the 10's call for.
edit: im getting 10's not 12's cherry. 10's work much better for my kind of music.
