Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
What happened to my truck!??
Old Jun 26, 2010 | 02:37 AM
  #101
AF_HEMI's Avatar
AF_HEMI
dude i've taken the door panels off MANY vehicles and NEVER had them come off as easy as the rams. its amazing honestly. heres how:
The fronts: remove phillips screw in triangle section covering mirror bolts, remove phillips screw behind door handle, remove both phillips screws at bottom of door, remove torx screw holding the handle to the lever mechanism. thats only 5 bolts total!! lift the panel and it just pops right off peice of cake. it takes literally 2 minutes if you dont have a clue what you're doing...30 seconds if you do.
the back is even easier. Only 2 bolts. the phillips behind the handle, and the torx inside the handle. lift and remove door panel.
so easy a caveman could do it...
Old Jun 26, 2010 | 05:11 PM
  #102
jake7's Avatar
jake7
AF--you done yet?!? ha I keep reading this thread hoping to see a finished product...WHERE IS IT?! Looks great so far
Old Jun 26, 2010 | 09:07 PM
  #103
AF_HEMI's Avatar
AF_HEMI
I WISH!!! i've run into a few non-truck related problems. I've got 3 papers totaling 18 pages due wednesday for my masters class that i havent started on cause i've been so focused on this build. As soon as it gets done, i'll be postin you can count on that. Thanks for watchin!
Old Jun 26, 2010 | 09:23 PM
  #104
Snakekillar's Avatar
Snakekillar
Originally Posted by AF_HEMI
$150 - resin
$30 - fiberglass mat
$10 - fleece
$30 - wood (frame/MDF top)
= $220 for the box
$50 covering/custom stitching
I'll have about $275 wrapped up in this box. So about the same as a nice prefab
How much fiberglass mat did you use? I would like to do this fiberglass box also. I bought a cheap prefab and im not happy with it. Not enough air space. I have never messed with fiberglass, so im learning from you. Keep up the good work!
Old Jun 26, 2010 | 09:52 PM
  #105
AF_HEMI's Avatar
AF_HEMI
you'll need about 12 sq ft per layer. you should do at least 4-5 layers, so roughly 50-60 sq ft. you'll also need 2-3 gallons of resin
Old Jun 30, 2010 | 02:02 PM
  #106
glass3222's Avatar
glass3222
How did the papers go?
Now get back to work on the truck
Old Jul 3, 2010 | 08:41 AM
  #107
BigTXRam's Avatar
BigTXRam
anymore update?
Old Jul 3, 2010 | 05:11 PM
  #108
jake7's Avatar
jake7
no kidding AF- are you in a deep depression after getting your grades on your papers??
Old Jul 3, 2010 | 08:21 PM
  #109
SilverBullet08's Avatar
SilverBullet08
lol he updates on another site lol must have forgotten about this one lol
Old Jul 4, 2010 | 11:20 AM
  #110
mikesa_tx's Avatar
mikesa_tx
Boooo!!! I was so in to this. I hope he comes back to update.
