Charger SRT-8 That thing got a Hemi? Indeed, a 6.1L Hemi that is. The Dodge Charger SRT-8 pounds the pavement with severe power.
0 to 60 timer.
Old 02-27-2008 | 11:05 PM
thomas.harrah's Avatar
thomas.harrah
Default 0 to 60 timer.
my best time out of about 10 times was a 5.28s ,has anyone done better?
was that good or bad ?
Old 02-28-2008 | 01:13 AM
ftnjun's Avatar
ftnjun
Default RE: 0 to 60 timer.
I've done 5.4, damn yours is fast....
Old 02-28-2008 | 05:21 PM
RamblinWreck's Avatar
RamblinWreck
ORIGINAL: thomas.harrah
My best time in my '07 Magnum SRT8 is 4.80 seconds. This morning I got 4.98 seconds. Most of the time I end up in the 5.2 to 5.4 range. The key is to minimize the wheel spin... on my 4.80 run I had virtually no wheel spin at all - almost a perfect launch.
Are you in a Charger or Magnum?
Old 02-29-2008 | 09:45 AM
MrC1's Avatar
MrC1
4.98 is my best and it had a plenty of spin. Since then I tried with a full tank of gas and could only muster 5.20s. [:-]
Old 04-06-2008 | 06:27 PM
1BADSRT8's Avatar
1BADSRT8
My best was 4.94 so far
Old 04-07-2008 | 09:59 PM
Nicky B's Avatar
Nicky B
Best I have seen is a 4.51 Buddy of mine has a mediumly modified SRT-8 charger dyno'd at around 415HP and 0-60 was had with meaty 285's from Nitto . In the fall he is adding performance heads and is hoping for 440HP and 0-60 of around 4.3seconds. To him its best to launch the car at 2500RPM.
Old 04-23-2008 | 03:31 PM
MrC1's Avatar
MrC1
I just did a 4.92 and still had to feather it pretty badly. I haven't tried brake torquing it yet. Might try that next, but I can;t imagine NOT having a traction issue doing that.
It's RIDICULOUS that we don't have limited slip back there. How retarded is that??
Old 07-06-2008 | 02:23 PM
ZC3000's Avatar
ZC3000
My best time in stock form was 4.84. After adding the Airaid intake and Predator Tuner, best time stands at 4.42
Old 07-06-2008 | 11:38 PM
Nicky B's Avatar
Nicky B
ORIGINAL: ZC3000
That inprovement in by almost .5second is hard to believe with just those modd's. Are you running drag radials when you did that run.
Old 07-08-2008 | 04:38 PM
MrC1's Avatar
MrC1
I agree - tell us about your tires! Very believable if you've got DRs or better.
I can't seem to break my old record regardless of the but dyno after the diablo tune. It's gotta be in the launch (traction).
Quick Reply: 0 to 60 timer.
