Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Sunroof issue, any ideas?
Old Aug 28, 2010 | 01:01 PM
lxman1's Avatar
lxman1
Site Moderator
Is it power or manual?
Old Aug 31, 2010 | 03:49 PM
lxman1's Avatar
lxman1
Site Moderator
I don't know much about them either. I wonder if a local glass shop might be a cheaper alternative to the deal.
Old Sep 1, 2010 | 04:52 PM
lxman1's Avatar
lxman1
Site Moderator
Good luck. Mine doesn't have a sunroof.
Old Sep 12, 2010 | 09:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Search Result
Vehicle Issue Sunroof inoperative, new sunroof motor installed and will not calibrate correctly.;Dealer has attempted to time the new motor and the operation is not correct.
System or Component Abnormal Behavior / Function,Inoperative,Will Not Program;Customer Concern (No DTCs),New / Remanufactured Part,Part Does Not Function Properly;Power Sunroof,Sunroof / Sunshade;Yes - Continuously
Recommendation MOTOR - SUNROOF WITH CONTROL UNIT DRIVE MOTOR TEACH PROCEDURE REPLACEMENT DRIVE MOTOR 1. Press and hold the sunroof close switch until the sunroof glass moves into the vent position and automatically reverses slightly and stops in the vent position. 2. Release sunroof switch. 3. Within five seconds of releasing sunroof switch, press and hold the sunroof close switch again until the sunroof glass fully cycles and returns to the closed position. 4. Release sunroof switch. Sunroof will now operate normally. ORIGINAL DRIVE MOTOR 1. Press and hold the sunroof close switch until the sunroof stops at the closed position. 2. Release sunroof switch. 3. Press and hold sunroof close switch once again for at least 10 seconds. After 10 seconds of pressing the close switch the sunroof glass will automatically move into the vent position and stop. 4. Release sunroof switch. 5. Within five seconds of releasing the sunroof switch, press and hold the sunroof close switch again until the sunroof glass fully cycles and returns to the closed position. 6. Release sunroof switch. The sunroof will now operate normally.
Try this first,it maybe just out of time or something did break.
