Transmission Problems
Old Apr 28, 2009 | 12:25 PM
thephife's Avatar
thephife
Default Transmission Problems
I have a 2001 Grand Caravan Sport and I love the thing I use it quit a bit for hauling my bands equipment and what not...anyways...
I was driving in the rain on the way to work and when I had exited and then proceeded to the service road, I went to accelerate and as soon as I had reached 1000 rpms the van acted like it had slipped out of gear.
So I pulled over turned the vehicle off sat for a second and then turned the car over and then it did the same thing.
So I tried to manually shift it, it still had the same results.
So I thought hmm...maybe reverse? Well I felt it go into gear but again when i tried to accelerate, not go.
Maybe the torque converter? Clogged filter? ECU?
Any leads will be great I alreayd have it in the shop but I am just curious...
Old Apr 28, 2009 | 01:07 PM
chopper's Avatar
chopper
Fluid level????
Old Apr 28, 2009 | 01:13 PM
thephife's Avatar
thephife
yeah it was fine.....but it looked kind of weak I know its transparent but...it jsut looked wierd, so i had a friend of mine look at it, he used to be a mechanic and he said the fluid looked fine and didnt smell burnt...
Old Apr 28, 2009 | 01:14 PM
thephife's Avatar
thephife
the other thing is that when I do get on the highway, and I get above 2000 rpm i have to take my foot off the gas to get it to shift...
Old Apr 28, 2009 | 06:56 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a rebuild is due. It sounds like the front pump is failing causing the slipping.
Old Apr 29, 2009 | 12:20 AM
master tech's Avatar
master tech
Site Moderator & Tech
You need to pull transmission codes and post them. But I would say you may have a broken planetary gear set. Remove the output speed sensor and ck for metal. If there is metal, then something broke.
Old May 1, 2009 | 10:51 AM
chopper's Avatar
chopper
Here's a link.
http://www.allpar.com/fix/trans.html
I was ready for a rebuild until I read the article posted.The tranny was going into "limp mode" but a new input speed sensor fixed the problem for a couple of years.The van started acting up again and before taking it to the rebuild shop,I read the link again to see if there was anything I could do that was cheap first.
A few paragraphs down,a mention was made of cleaning the eight pin connector where it connects to the transmission.I did this two months and 3,000 miles ago and so far the problem is gone.
So,check out the link and maybe you can save some money.It could only be a solenoid pack or a corroded connection.
Good luck and keep us posted.
