2002 Caravan Air bag light On
Old Jan 26, 2010 | 05:51 PM
  #21
master tech's Avatar
master tech
Site Moderator & Tech
vladhed
Open the glove box door and drop.Find the yellow connector thats next to the radio. Unplug the connector and ck the pins, Some times when you get high resistance the air bag lite will come on, or an open circuit will too.Clean the connector and plug back together.
Old Jan 27, 2010 | 08:35 AM
  #22
rick31797's Avatar
rick31797
Since i posted this, the air bag went out for a short period ( 30 Kms ) and then back on again.
Then last Dec it went out again and has not come back on.
Rick
Old Jan 27, 2010 | 12:46 PM
  #23
master tech
Rick
Do you still have the same code?
Old Jan 28, 2010 | 09:06 AM
  #24
rick31797's Avatar
rick31797
Thats a good question , i never even thought too check. So i went out and try it and the first time i did it i got d.o.n.e no codes tryed it twice more and nothing is coming up.. Before i was getting the code 0.456
So here is hoping it is fixed, but i am not too sure.
Rick
Old Jan 28, 2010 | 12:34 PM
  #25
master tech
Rick
You'll need to scan the SRS Module for the air bag codes. If its the same you had before, which i think was the pass squib module. Then the module may have a problem. I don't know what or how much warranty you may have on it, But you may want to call the dealer and see if it may still have any warranty left.
Old Jan 30, 2010 | 10:55 PM
  #26
xeroguitar2003's Avatar
xeroguitar2003
Originally Posted by 92dak5.24x4
a code reader is totally useless beyond engine driveability issues. So to answer your question, No, you just can't plug in a code reader into the engines computer. I can't believe this is your first vehicle to have an air bag. you've never owned a vehicle newer than 1994 until now? That's increadible. since your making the statement that risk factor is low, then just put a piece of black tape over the light and ignore it. Then you're no worse off than all the vehicles you've had before this one.
I have read several post by you and plain and simple....you are a dick!!! If someone asks a question they expect the responses to be helpfull, not rants of useless insults.....
Old Jan 31, 2010 | 04:32 PM
  #27
hydrashocker's Avatar
hydrashocker
That's enough of the BS and taunting behavior!
92daak.24x4<----- You need to chill out! Not everyone is a Certified Mechanic! Drop the attitude!
Xeroguitar2003<-----Although you maybe correct in his attitude, you are being an aggressor as well. Please settle down.
Old Feb 1, 2010 | 09:29 AM
  #28
xeroguitar2003
I believe we have come to an understanding on this issue, VIA PM's. Not trying to be an aggressor just trying to be an internet vigilante
Old Feb 1, 2010 | 09:46 AM
  #29
jesus el guappo's Avatar
jesus el guappo
why did you only pick this one entry to be some sort of troll? and I can't believe a moderator basically calling a member a dick.
Old Feb 1, 2010 | 03:13 PM
  #30
master tech
jesus el guappo
You did not need to post, what you did.You don't use the term that you just use either. So don't keep something going that have no ideal about.
