check engine - 1994 dodge caravan 3.0
Old Feb 25, 2010 | 07:30 PM
tonyvu's Avatar
tonyvu
Default check engine - 1994 dodge caravan 3.0
My engine light came on and my mechanic scanned it to no avail
what do you think the problem is?
Old Feb 26, 2010 | 10:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Was the tech trying to pull codes from the blue connector under the dash or the black connector under the hood? There is one other way of checking for codes for the engine with a scanner. Turn the key on and off three times and leave the key on after the third time. count the flashes and post.
Old Feb 27, 2010 | 01:09 PM
tonyvu's Avatar
tonyvu
I will ask my mechanic to give it a try with your idea
Old Feb 27, 2010 | 01:46 PM
tonyvu's Avatar
tonyvu
and he checked under the hood
Old Feb 27, 2010 | 02:31 PM
tonyvu's Avatar
tonyvu
and by on do you mean the car ignition ignited or just on for electricity
Old Feb 27, 2010 | 02:56 PM
master tech
Key on engine off. Not running.
Old Feb 27, 2010 | 09:10 PM
tonyvu's Avatar
tonyvu
i tried the test 3 times
2 times the light flashed 3 times and then paused for a few seconds and then the 3 pattern again
1 time it was 5 times
also do you think it could possibly be from a break in? Someone broke into my car the same day this started happenning
Old May 5, 2013 | 03:51 PM
hotrod52neon's Avatar
hotrod52neon
where can i find 1994 dodge caravan engine codes
