Limp Mode
Old Apr 9, 2010 | 11:13 PM
azshadeguy's Avatar
azshadeguy
Default Limp Mode
My son has a 95 Caravan stuck in limp mode. He put a new trans filter and ATF4 fluid in it and it shifted perfect the first time it was driven. Also he says if you take off in a hurry it will shift fine until you slow down then it jumps down into second gear. How do you test for codes on the 95?
Old Apr 10, 2010 | 12:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
There is a blue connector under the dash near the fuse box panel. This is for the transmission controller and abs. Pull the codes for the transmission and post.
Old Apr 10, 2010 | 12:39 AM
azshadeguy's Avatar
azshadeguy
Originally Posted by master tech
Welcome to DF
Do you use a obd reader?
Old Apr 10, 2010 | 11:15 AM
master tech
I would use a DRB2 or DRB3. I don't think a obd code reader would work.
Old Apr 10, 2010 | 01:17 PM
azshadeguy's Avatar
azshadeguy
Is that something a dealer would have to do?
Old Apr 10, 2010 | 01:32 PM
master tech
Yes they would.
Old Apr 11, 2010 | 01:20 PM
azshadeguy's Avatar
azshadeguy
Is there any other way to test this transmision. He doesnt have the money to take it to the dealer.
Old Apr 11, 2010 | 07:44 PM
master tech
If you have a friend that works at a dealer, ask them to pull codes out for you. Or someone you know at the dealer.
