Transmission Trouble When Cold
Old 11-12-2010 | 05:42 PM
dco's Avatar
dco
Default Transmission Trouble When Cold
2000 Plymouth Grand Caravan (Rampvan Handicap conversion) 3.3L. When starting on cold days (below 40 degrees), vehicle doesn't go into gear correctly. Van wants to rev up before grabbing the gear. Very dangerous when at a traffic light and car is still cold. Won't grab the gear until it warms up.
Recently didn't grab to almost 2,000 rpm, then check engine codes of P0700 and P1872 and check engine light. Once warm drives super. Has almost 100k miles and has been pretty well cared for. Started being tricky to shift from reverse to drive last winter, but is much worse this year now that it starting to get cold here in the Northeast.
All thoughts appreciated.
Old 11-12-2010 | 11:54 PM
lxman1's Avatar
lxman1
Site Moderator
If the fluid is full, then it is usually a sign of bad things to come.
Old 11-13-2010 | 12:59 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I think you mean P1782 which is a 2/4 pressure code. Ck the fluid level, i am guessing you are low on fluid and should also have a loss of prime code too.......P1791
Old 11-14-2010 | 11:21 PM
vitual's Avatar
vitual
I also Have similar problem, my 2002 GC sport, will not grab 1st gear after I make first stop in morning. it would go to drive normaly but when i would make my first complete stop, it wont grab the first gear after that until i rev upto 2-3 K , then with sudden jerk, it would grab the first gear and there wont be this problem again ever for the day. Next morning this will happen again. Transmission fluid level is ok.
Old 11-14-2010 | 11:22 PM
salmonz's Avatar
salmonz
I've had this problem too. Still don't know what causes it. Fluid is ok.
Old 11-15-2010 | 12:07 AM
master tech
Here is a tsb that may help.
SUBJECT:
Transaxle Slips In Reverse Or First Gear
OVERVIEW:
This bulletin involves replacing the low/reverse accumulator cover and
O-ring during transmission repair.
MODELS:
2002 (JR) Sebring Sedan/Sebring Convertible/Stratus Sedan
2002 (PL) Neon
2002 (PT) PT Cruiser
2002 (RS) Town & Country/Voyager/Caravan
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH AN AUTOMATIC
TRANSAXLE WITH BUILD CODE DATES OF 1342 (MAY 14, 2002) THROUGH
AND INCLUDING 1502 (MAY 30, 2002). REFER TO THE APPROPRIATE
SERVICE MANUAL OR MDS2 SERVICE INFORMATION FOR THE TRANSAXLE
LABEL LOCATION AND CODE INFORMATION.
SYMPTOM/CONDITION:
Some vehicles may have a transaxle that will not move or slips in Reverse or First gear.
DISCUSSION:
Vehicles equipped with automatic transaxles built in the range specified that exhibit
the condition(s) listed above may also have Diagnostic Trouble Code(s) (DTC)
P0736, Gear Ratio Error In Reverse, or P0731, Gear Ratio Error In 1st set. All
vehicles that fall in this category must have the Low/Reverse Accumulator
Cover and O-Ring replaced during transmission repair.
PARTS REQUIRED:
Qty. Part No. Description
1 04431617 Cover, Low/Reverse Accumulator
1 06501549 O-Ring, Low/Reverse Accumulator
Old 11-15-2010 | 10:36 AM
dco's Avatar
dco
Red face Trans Code 1782 and 0700
Fluid level is good. Vehicle has 97,500mi. Never used or leaked trans fluid. This is only a problem when cold and outside temps are below 40 degrees F.
Vehicle was build about June 1999.
Ideas?
Old 11-15-2010 | 11:18 AM
vabear's Avatar
vabear
Default Tansmission Slips at Low Temp
I have seen this happen when the incorrect traqnsmission fluid has been used (something other than ATF+ 3/4).
Old 01-17-2011 | 08:15 AM
vitual's Avatar
vitual
SUBJECT:
OVERVIEW:
MODELS:
2002 (PL) Neon
Is this TSB only for 2.0 L and 2.4 L or it applies to 3.3 L engines too ! when i searched over internet , it said it does not apply to 3.3 ??
Old 01-17-2011 | 11:38 PM
master tech
Thats for all 4 speed automatic transmssions.
Quick Reply: Transmission Trouble When Cold
