tranny cooler, dodge auto doesn't know
Old Dec 16, 2010 | 04:38 PM
scotter5's Avatar
scotter5
Default tranny cooler, dodge auto doesn't know
grand caravan 3.8--going to remove the rubber host from the metal line and clamp it. Dodge dealer doesn't know
what is inside diameter of the hose so i can pull it over the metal line with the flare?
What is best say to remove crimp holding hose and metal line together so not to damage the metal line
Old Dec 16, 2010 | 05:06 PM
lxman1's Avatar
lxman1
Site Moderator
Most I've seen have been 3/8", but not certain on your van. Just make sure you use line that is made for transmission fluid and not fuel line. Transmission hose is usuallt thicker walled and is made to hold up to the chemicals in the fluid. I've never had a hose off of my 07.
Old Dec 16, 2010 | 05:12 PM
scotter5's Avatar
scotter5
thanks, not getting any response to this question. thanks for giving me a reply
"were in it together."
Old Dec 17, 2010 | 10:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
What year is the van, this way i can look it up myself. By the way i bowl on thursday nites,so i not on the forum.
Old Dec 18, 2010 | 08:14 PM
scotter5's Avatar
scotter5
06 grand caravan--thanks--no gutter *****, just "x"
Old Dec 19, 2010 | 08:27 PM
master tech
Okay, you have the quick disconnect lines. Here are the part numbers you need,these are mopar numbers. Lines 4677680AC, connectors at the transmission case 4800267AA. These part numbers are from 2005 thru 2007. Now if you need the part numbers from the early years let me know.
Old Dec 19, 2010 | 08:40 PM
scotter5's Avatar
scotter5
hi master tech. what i really needed to know is what size the inside diamter of the rubber hose part of the tranny line is? I asked the parts guy, service guy and also a dodge mechanic in back what the the i.d. of the hose was of the line was. they didn't know. would you know?
Old Dec 19, 2010 | 10:11 PM
master tech
If you are just replacing the hose. Its 5/16 and the part number for the hose clamps are 4596424AA.
Old Dec 20, 2010 | 11:14 AM
scotter5's Avatar
scotter5
thanks master tech for the info. that i needed to know.
i guess the clamps are the the clamps with the slots on them worm gear
i have seen some different agreements on the issue of the clamps some say fuel injection others say worm gear.
again, much thanks for taking time to respond. have a good christmas and new year.
Old Dec 20, 2010 | 05:04 PM
hemi4spd's Avatar
hemi4spd
not to disagree with a gear clamp, it will work just fine, I just prefer the FI clamps as I find they clamp better
