1998 caravan 3.3 transmission issue
Old Feb 5, 2011 | 11:09 AM
aruiz865's Avatar
aruiz865
No bad sounds and it doesn't roll in park on in N with the van off when the van is on wont move at all...pulled speed sensor and it had metle on the end thinking of having it rebuilt have got a qoute for 2000 just wanna make sure it'd nothing easy before I take it in
Old Feb 5, 2011 | 12:35 PM
22DODGE22's Avatar
22DODGE22
Not quite clear on your answer: It doesn't roll at all in Neutral? Like it's locked in park?
$2000 for a transmission is freaking rediculous. I got a quote like that for my 1995 stratus trans. I ended up fixing it for under $100 but it took a few days of labor for me to remove the transmission, determine problem, find parts, fix and assemble.
Old Feb 6, 2011 | 01:44 AM
master tech's Avatar
master tech
Site Moderator & Tech
The member may have meant it doesn't roll in neutral with the engine running.Thats how i read it. But i not always right.
Old Feb 6, 2011 | 07:46 AM
aruiz865's Avatar
aruiz865
Your right that's what I ment
Old Feb 6, 2011 | 09:10 AM
22DODGE22's Avatar
22DODGE22
Doesn't roll in Neutral with engine running: problem is destroyed planetary gears.
Doesn't roll in Neutral with engine off: Diff pin jambed against case.
Old Feb 15, 2011 | 06:37 PM
aruiz865's Avatar
aruiz865
Got it apart and the planetary gear Were destroyed thanks for all the help guys
Old Feb 15, 2011 | 07:19 PM
22DODGE22's Avatar
22DODGE22
There is one main thing that causes that failure: Trans cooler blockage.
Old Feb 16, 2011 | 02:25 PM
aruiz865's Avatar
aruiz865
I had it looked at at a shop and the actually rebuilt it for me and checked all lines
Old Feb 16, 2011 | 07:58 PM
22DODGE22's Avatar
22DODGE22
Better make darn sure they super flushed the trans cooler.
