Cruise not working after installing
I have a 1997 Dodge Caravan, its the basemodel (Not even power mirrors). I have installed Power Windows, Installed the motor for the locks and ran the wires (Can't figure out how to hook them up as there are only 2 wires for the switch and motor) and installed Cruise Control. I removed all the parts from a 1996 Dodge Grand Caravan that was in my local wrecking yard. I have also swapped most of the interior (Seats,Door Plastics,etc). I have ran the wires as the repair manual states there are originally hooked up, The wire for the Cruise Control (thing) under the hood was allready there. When I press the On/Off Button I hear a click, Every time I press it it makes one click, I have had my father press the button while I am under the hood and its coming from the (thinggy) that controls the cruise. The cruise will not set and hold a speed. Anyone have any advice? Same goes for the power locks? How do I hook them up?
Thanks in Advance.
3.0L V6 169686KM
3 Speed Automatic
If you need more info just ask.
Thanks in Advance.
3.0L V6 169686KM
3 Speed Automatic
Hi,
I forgot to mention, I also changed the whole steering column with one that has tilt and cruise already, The airbag light is not on, And the clicking that the cruise control servo is making is telling me that there is a connection from the steering wheel. This van did not have cruise when it was new.
Trending Topics
Well
Like I said, this van was a bottom of the line van, I installed all the parts off a 1996 dodge grandcaravan, ran a line to the wire on the PCM that was/would have been usedfor the cruise if it came with it, ran the ground to ground, and tapped into the brake light sensor above the brake pedal as it would have been if it had came with cruise, the wires for the servo was already under the hood and all I did was plug the connector in. I have also replaced the cruise control dimmer module inside the column as I had thought it might be that, did not make a difference, also replaced the module for the brake and it did not make a difference either.
