wiring issues - 2nd gear only!
Old Jun 18, 2011 | 10:14 PM
peshewa's Avatar
peshewa
Default wiring issues - 2nd gear only!
Hey guys, I have a 1996 T&C 3.3 auto, I replaced the tranny solenoid a few months back & it was still stuck in 2nd, so I disassembled the main wiring loom that runs under the radiator to reach the tranny computer. There were 6 or more wires that were just burnt in 2 and most of it all was coated in battery corrosion. I have since discovered that a fuse box full of silt means I bought a van that was underwater. I did the repairs in sub zero temps with numb hands then it shifted just fine, but I had to remove the fuse for the interior lights because they would drain the battery fast. I tried to fine tune that old repair & replaced another wire, but now I am stuck in 2nd gear again. Does anyone have a good clear wiring diagram for that loom that goes across the bottom under the radiator? I know I need to just replace it or junk this & get another, but the engine runs great & I am pretty broke. I have a large spool of high quality 16 gauge wire to use, but I need a clear game plan this time. Please someone help me with a diagram!
Old Jun 19, 2011 | 05:30 PM
master tech's Avatar
master tech
Site Moderator & Tech
Hi Brian
Did I sent you some diagrams? If I didn't, send me a pm with your email address.
Old Jun 19, 2011 | 11:09 PM
peshewa's Avatar
peshewa
Even more fun! I spent the entire day carefully disasembling the engine wiring loom & I replaced all the wires that lead from the tranny solenoid to the tranny PCM 1 at a time, still stuck in 2nd gear. I heard someone on a similar post mention that their tach went ape when this happened to them and there was another circuit leading to a sensor that could cause this, but my tach works fine, no jumping at all. I also have to leave the fuse for the interior lights out or the battery runs down in about 3 hours. I do suspect it has been under water before I bought it because the fuse box had lake bottom type silt all around the relays & fuses, and there was a ton of corrosion in there. I replaced all fuses & some for the relays, but I think the fuse box may even be too far gone. it sucks because the tranny was shifting fine & the engine runs great, but I may have to ditch this thing for something less troublesome soon. It really sucks because I am starting to like having this van even though I have no family.
Old Jun 26, 2011 | 04:31 AM
peshewa's Avatar
peshewa
I was about to tear back into the harness, but I changed out some relays instead, now I have a fully operational transmission. Whoda thunk it? The fuse box is full of corrosion and I should likely replace it.
Old Jun 26, 2011 | 01:38 PM
master tech
If the fuse box has corrosion. I would either clean it up or replace it.
Old Jun 26, 2011 | 10:45 PM
wtribeflyer's Avatar
wtribeflyer
Please tell us what relays you changed that you believe fixed the tranny shifting issue!! Thanks
Old Jun 29, 2011 | 07:42 AM
peshewa's Avatar
peshewa
I replaced the EATX & the ones around it just to be safe with some I got form the junk yard out of another van. I removed the fuse box in an effort to do a detailed cleaning job, but as I got into it from the bottom, I found it is layer after layer of a sort of curcuit board with stuff that falls out everywhere, so I just put it back together & crossed my fingers. I will get another fuse box asap, but next are window motor assemblies (new) & a wiper switch (used) & a rear wheel bearing.
Old Jul 2, 2011 | 02:36 PM
Dezik's Avatar
Dezik
peshewa,
Just curious my 2000 Dodge Grand Caravan is stuck in limp mode as well and have changed out both the input and output sensors with no change. I am looking in my book right now to find the EATX relay. My van was driving awesome then all of a sudden wouldnt go out of limp mode. The speedometer and odometer stopped working and the P D N R... have squares around them. It still drives find just at about 2500 rpms. I am desprate cant afford to take it to a shop and hubby been out of work for almost 3 years. Any advice is muchly appreciated.
