96 GCV, AC problem
Old Aug 7, 2011 | 11:41 AM
ez1913's Avatar
ez1913
Question 96 GCV, AC problem
1996 GCV, 3.3lt, 203K miles.
Just replaced my compressor and dryer.
Has a local shop vac it down and charge it up.
I was sure to give the mechanic to card attached to the new pump that stated it had 1.5 oz of oil already in it.
I have no idea how much more oil he put in.
At idle, the air is cool at best. I have to be doing 45mph to get cold air.
I checked the low side pressure and it was pretty high, so I burped off about 10 lbs.
It's been very hot here, over 100, for a month.
Coming home from a roadtrip in 112* heat, my temp gauge started to rise.
I've never seen it go past half... EVER!
Would an overfill of oil cause these problems?
How can I tell if the system has to much oil?
Can you drain oil out without losing charge?
Thanks,
EZ
Old Aug 7, 2011 | 03:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you replace the expansion valve?
Old Aug 7, 2011 | 04:29 PM
ez1913's Avatar
ez1913
I did not.
The system was working great, until the compressor pulley went bad.
I replaced the filter/dryer just because it's easy to do and seemed like a smart thing to do.
I suppose I must have the system discharged to replace the valve, right?
PinCup
Old Aug 7, 2011 | 07:09 PM
master tech
Sorry, Yes you do.
Old Aug 7, 2011 | 09:31 PM
ez1913's Avatar
ez1913
EZ
Old Aug 7, 2011 | 11:13 PM
master tech
Let go to another subject. How's the bowling center doing? I know winter season coming up soon.
Old Aug 8, 2011 | 10:27 AM
ez1913's Avatar
ez1913
Cool
We had to back away from that deal.
The seller had way to much debt, I guess he was hoping we wouldn't find out.
The center is in foreclosures right now, so we're waiting to hear from the bank.
They are aware of our intentions.
I may be heading to Utah to help a failing bowling center there. (1200mi with a flaky AC )
Hard to turn a profit when nothing runs. PinCup to the rescue!
That will kill some time and I'll make a buck while we wait for the bank to do it's thing.
EZ
Old Aug 8, 2011 | 06:36 PM
master tech
Sorry to hear that. I thought you guys were doing okay. Good luck with the bank, I'm sure it will work out.
