odd no start
Old Sep 23, 2011 | 05:24 AM
missmydodge's Avatar
missmydodge
Default odd no start
ok 2000 grand caravan i try to start it i get a click then (and heres the odd part) the dash and running lights start to flash , like it has a alarm.... but no horn . the horn works but for some reason the power windows dont now . it gave some starting issues for a little while just try it a few times and it would start but now nothing , im lost
Old Sep 23, 2011 | 12:06 PM
22mopar22's Avatar
22mopar22
a very comon problem I've come across on these vans with similar symptoms is the little ground wire at your battery cable. the negative side has a large cable and a small wire attached to the clamp bolt. you wouldn't believe the number of times cleaning or just tightening fixes the problem like yours.
Old Sep 24, 2011 | 02:44 PM
missmydodge
ill try that later today ... but why would that cause the no start? or the odd lights?
Old Sep 24, 2011 | 02:58 PM
Cougar41's Avatar
Cougar41
Microprocessors on these vans (in computers/modules) and in general, are sensative to low voltage and power fluctuations due to unstable power sources. That could mean a weak battery or as 22Mopar22 pointed out, loose/corroded connections. When you attempt to start, the demand on your vans electrical system is at it's highest. A power drop due to a weak battery or across a poor connection compounds the draw, leaving little power for your starter and the modules. For lack of a better term, the microprocessors go spastic resulting in the uncommanded displays you're seeing. Clear as mud?
Old Sep 24, 2011 | 03:03 PM
steak59's Avatar
steak59
Have u tried to jump start ur van?
Old Sep 24, 2011 | 06:46 PM
22mopar22's Avatar
22mopar22
what's so hard about spelling out YOU and YOUR?
Old Sep 24, 2011 | 06:49 PM
steak59's Avatar
steak59
finding short cut to get the job done, part of being a mechanic, lol...
Old Sep 24, 2011 | 08:32 PM
22mopar22's Avatar
22mopar22
Short cuts are one thing, laziness isn't a short cut.
Old Sep 24, 2011 | 11:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
Isn't that what flat rate does too. Make short cut and being lazy too?
Old Sep 25, 2011 | 09:16 AM
22mopar22's Avatar
22mopar22
no not lazy, that's a case of how knowledge, skills, practice and pragmatic problem solving skills reduces the time involved. that's not being lazy. And even a Master tech, doesn't display laziness when it comes to spelling out YOU and YOUR.
