Chirping worse. Boy do i screw up. Help.
Old Jan 9, 2012 | 06:44 PM
  #21
scotter5's Avatar
scotter5
HOpe you don't need to buy the tool. of course you could re-sell it.
maybe you can find a rebuild shop to take it off.
I'll tell you one thing--it is certainly good not to hear that noise. i use to not want to enter the van and drive it b/ of the noise. now i look forward to hearing the purr
Old Jan 10, 2012 | 08:31 AM
  #22
Annihilator_X9's Avatar
Annihilator_X9
You WILL need the Gates tool to remove it and put the new one on. I had to replace mine because it was making the same sound.
Here's mine:
http://www.youtube.com/watch?v=9ziWJ...8&feature=plcp
Old Jan 10, 2012 | 10:21 AM
  #23
scotter5's Avatar
scotter5
The tool was too much money, so i went to rebuild alt. shop. they took off and put my new one on for 13.50. they took it off in about 3 mins with a "snap on" tool. If so inclined you could remove it yourself. you will need 10 mm with ext. it will have to go through the center of a coupler nut bought a home depot or such that is 17mm with 16 sides, this will be used to hold the side of the inner pulley when the 10mm is turned. Getting a guy to take off pulley was the best deal though.
Old Jan 10, 2012 | 02:04 PM
  #24
Annihilator_X9
The tool broke when I did it actually. Used an impact wrench on the pulley itself and it came right off. Spun the new one right back on. I hoped it would hold, and so far it had.
Old Jan 10, 2012 | 06:29 PM
  #25
scotter5's Avatar
scotter5
That is awesome. So, you put in a 10mm socket on the nut down inside but didn't you have to hold the pulley from moving when you spun it loose with some 17mm hex?
Old Jan 10, 2012 | 09:38 PM
  #26
steak59's Avatar
steak59
Nope, Impact guns works differently, you can hold the pulley with ur hand.
If you are using hand tool, you can use a Band type strap wrench the hold the pulley.
Or you can stick a screw driver inside the Alternator and jamp the rotor in place like a red neck.
