Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
Yes, the output sensor could fail and not give you a code. But so could the input sensor too. You could try replacing both sensors and see if that fix the problem. And there has been a small problem with the output sensor connector too. But the wire in most cases, break inside the connector.
i have to sensors to put in on friday we will see what happens from what i under stand could also be a problem inside the trans making the solnoid pack freak out as well hope not.
