05 caravan no start
Old Sep 21, 2012 | 05:44 PM
MillerMan's Avatar
MillerMan
Default 05 caravan no start
A friend of mine has a 2005 caravan with the 2.4L that wont start. Just replaces the fuel pump coil and crankshaft positon sensor. When u open the drivers door the Odometer comes on is that normal. If you have any ideas please let me know.
Old Sep 23, 2012 | 11:01 PM
master tech's Avatar
master tech
Site Moderator & Tech
Remove the cam sensor and have someone crank the engine over and watch the camshaft. Does the camshaft rotate with the engine cranking over. If it doesn't, then the timing belt is broken.
Old Sep 23, 2012 | 11:06 PM
Cougar41's Avatar
Cougar41
Now why didn't I think of that! Hey thanks MT. I've often wondered how you check for a busted TB on a distributorless ignition other than to just listen to the engine turn over.
Old Sep 23, 2012 | 11:08 PM
master tech
Thats because i have been doing this for 100 years. Ready to get out.
Old Sep 23, 2012 | 11:21 PM
Cougar41's Avatar
Cougar41
Well when you finally get out please stay with the forum. You're helping a whole lotta people.
Old Sep 24, 2012 | 08:20 PM
MillerMan's Avatar
MillerMan
i check the timing belt that is fine. is ther a way to check Fuel presser?
Old Sep 24, 2012 | 10:48 PM
master tech
Do you have a pressure gauge? And if you do, what is your pressure reading. Or you can disconnect the line and use a jar or large coke bottle. Just turn the key on and don't try to start. Do you have a good flow? Also remove the spark plugs and see if they are fouled with fuel. Also i don't think you said if you have spark at the plugs.
Old Oct 2, 2012 | 10:20 PM
MillerMan's Avatar
MillerMan
removed the fuel line no fuel came out. and the was no spark at the plugs. i changed the coil and still no spark.
Old Oct 2, 2012 | 11:47 PM
master tech
Have you checked the fuse for the ASD relay? Because that will control your fuel and ignition coil. Also does the engine crank over? If it does, i would also check the compression.
