ABS Light help
Have a 2002 Town and Country . Had driver front wheel off while greasing the tierod. Put the wheel back on and drove car, the ABS light was on and won't turn off now . any ideas what might have happened and what I can do to fix it ? I did disconnect the battery but that didn't reset the light . Thanks
Pulled the codes from the ABS
- # 10 - ABS Valve Power Feed Malfunction ...could this be from pulling the fuse out to see if that set the light off ??I have no idea what this is ??
- # 2 ABS Left front speed / signal
- # 6 ABS left rear speed / signal
Is the left the drivers or passenger side as it differs depending on where you are ?
Once we cleared the codes BOTH the ABS and Brake light went out and when I drove it they BOTH came back on at the same time
