[4th Gen : 01-07]: No Start - No Power to Starter
#21
Update;
It is not starting.
I re-checked the 30 and 87 relay. It did crank. Previously I was using a wire that did not go deep enough.
Battery is 12.3V, but still cranked.
Pin 30 has 12V
NO POWER at pin 86
Grounded pin 85 and turned the key; it started.
HOWEVER; After doing the check at pin 85, it has now started a few times on its own, as it nothing was wrong.
Thanks again for your help!!!
It is not starting.
Pin 30 has 12V
NO POWER at pin 86
#24
well.....I have thrown in the towel again. The Dealership could not find it either. They installed some LED lights for the next time in does the "no start". They are installed in a way that is not that different from the tests that you recommended. He said that it will work better than just using the multi-meter....at this point, I am willing to try it.
As of now it is running.
Thanks for following the thread, your help is appreciated!
#25
Got a hunch a new IPM is in your future. Internal circuit boards often fail.
"They installed some LED lights for the next time in does the "no start" Well hey, that's a new one and from a dealership to boot. Great idea. They should have incorporated that into the IPM on every van. Starting problems are the single most common complaint.
Just curious. Are the LEDs installed at the IPM or elsewhere?
#26
.... I never checked the ignition fuse (duh?), it was blown. The Garage replaced it, but it blew right away. End result is that they do not know what has caused the fuse to blow. They have increases it to a 20 amp, so far the van is working. Possibly a rusty starter or an exposed wire is causing a short.
#28
