[3rd Gen : 96-00]: Alignment after new F struts - 2W OK? Cost est?
Old 02-29-2016, 06:26 PM
hobkirk's Avatar
hobkirk
hobkirk is offline
Default Alignment after new F struts - 2W OK? Cost est?
I just put in new F struts (Monroe Quick, pre-assembled, $120 each), both F axles, new wheel bearing. Driving is SPOOKY!
Is just a front end alignment sufficient? And how much should an alignment cost?
THANKS
Old 02-29-2016, 08:32 PM
jkeaton is offline
Dodge Forum Administrator
THANKS
Did you have to disconnect the tie rods? Unless something was not installed correctly it should not affect drive ability that bad. An alignment may work or at least find out what is wrong.
Old 02-29-2016, 09:08 PM
hobkirk's Avatar
hobkirk
hobkirk is offline
No disconnect on tie rods or ball joints, although I did replace a wheel bearing.
Old 02-29-2016, 10:41 PM
primem's Avatar
primem
primem is offline
if you put in quick struts with new springs....you should get an alignment. Anytime ride height is changed....which it will after old saggy springs are replaced...the toe settings will change.
If you put the old springs back; it probably won't be out much as the lower bolts are splined and have no room for movement. the upper mount has a little room movement but not much. If you drive it and the steering is off-centered, its out. If you have new, good tires, get it done to save the tires from irregular wear.
Since the rear axle is a dead axle with no adjustments they should be charging you for a 2 wheel thrust alignment which is 1.5 hours. Do not get a 2 wheel alignment. a 4wheel alignment is 2.0 hrs.
a 2 wheel thrust alignment uses 4 wheel mounted heads. This measures the rear alignment angles and sets the front toe to match the rear thrust angle. 2 wheel alignments should never be done anymore as they set the front toe up to a geometric centerline. Problem being, if the thrust angle is not zero...the front toe won't be set up correctly.
Old 03-01-2016, 07:48 AM
kuyabribri's Avatar
kuyabribri
kuyabribri is offline
Depending on how long you plan on keeping the car and how conveniently located a Firestone shop is to you, you might consider getting the Firestone lifetime alignment deal. I bought it 5 years ago for my van for about the cost of 2 alignments and I'm to the point where I just have them do an alignment whenever I bring it in for a tire rotation.
Old 03-01-2016, 08:01 AM
jkeaton is offline
Firestone will also do an alignment check for free and tell you it needs to be aligned before doing anything to it. At this point, you need an alignment check.
Old 03-01-2016, 08:45 AM
hobkirk's Avatar
hobkirk
hobkirk is offline
Interesting. $190 vs $80. Unfortunately the closest Firestone is too far away.
Old 03-01-2016, 04:50 PM
smokesxt's Avatar
smokesxt
smokesxt is offline
You need an alignment. I did struts on mine and it took 1 trip to work and back (30mi) to destroy my front tires, as the new ride height up front from new struts threw the whole alignment out.
Quick Reply: [3rd Gen : 96-00]: Alignment after new F struts - 2W OK? Cost est?
