2003 dodge caravan sport
Old Feb 5, 2022 | 09:35 AM
harper1964's Avatar
harper1964
Default 2003 dodge caravan sport
van was running fine got home from work parked it, went out the next morning would turn over and try to start but wouldnt stay running, i can hear the fuelpump kick on run a couple
seconds and kick off like it should, check relays and fuses, reset security system, new batteries in the key fob,good charged battery,i can spray carb cleaner in throttle body
still the same, it does try and start but just kind of kicks like it wants too
Old Feb 5, 2022 | 10:14 AM
Welcome to DF! Moving this to Caravan section for ya.
Old Feb 5, 2022 | 11:08 AM
harper1964's Avatar
harper1964
thank you so much
Old Feb 6, 2022 | 03:18 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did start and stall 3 times and stop cranking or will it crank. If it cranks, sound like you are not getting spark to the plugs or the plugs are fouled. On the rear cylinder head see if the injector wire harness is shorted.
