5w20 vs 0w20
Old 10-16-2007, 11:09 AM
Hardcharger's Avatar
Hardcharger
Hardcharger is offline
Default 5w20 vs 0w20
Had the oil change done today, noticed the guys putting in 6 qts of synthetic mobil1 0w20. Asked about the difference between the specified 5w20 and 0w20 and was told there really wasnt too much and it wouldn't hurt. Went ahead and topped off the last quart with 5w20. Now, did I just get screwed?
Old 10-16-2007, 11:49 AM
MangoInTX's Avatar
MangoInTX
MangoInTX is offline
Charger Moderator
Default RE: 5w20 vs 0w20
I don't think you messed anything up.
Old 10-16-2007, 02:07 PM
Bigfoot68's Avatar
Bigfoot68
Bigfoot68 is offline
It shouldn't affect anything. The only thing I have read about being an issue is that with the wrong weight oil your MDS may not work correctly (I think this more a case if you put in a higher weight ie. 10w30). Other than that you should be fine. 5w20 is for the 5.7L and 0w20 is for the 6.1L
Old 10-16-2007, 05:16 PM
74scamp's Avatar
74scamp
74scamp is offline
I've wondered about this myself. Let us know, either way, if it works or not.
dave
Old 10-16-2007, 08:08 PM
Hardcharger
12 hours of running around town and so far so good...
Old 10-19-2007, 04:38 PM
74scamp's Avatar
74scamp
74scamp is offline
MDS still working "normally"?
Old 10-20-2007, 07:29 PM
Hardcharger
it sounds like it is, i'll know for sure in a few days when the old fuel needle has dissappeared to the left side of the gauge...
Old 10-21-2007, 05:21 PM
lewpuckett's Avatar
lewpuckett
lewpuckett is offline
you should be fine. the mds only has a problem with heavier weight oils. mobil 1 is one of the best oils in the world also. do not worry.
Old 10-22-2007, 08:41 AM
charginscott's Avatar
charginscott
charginscott is offline
I have always hear that the heavyer weight oil would render the MDS useless. I know they use 0w20 oil in the 6.1 cars.All should be ok but keep us posted.
Scott
Old 01-05-2008, 12:19 AM
atnyman's Avatar
atnyman
atnyman is offline
I use o-20 amsoil for 3mounths now no problems
Quick Reply: 5w20 vs 0w20
