Sponsored by:
Sponsored by: CARiD
code302
Old Jan 19, 2022 | 09:28 AM
Laurent1963's Avatar
Laurent1963
Default code302
  • 2013 Dodge Charger 3.6 engine. non flex fuel
  • Faulty or worn spark plugs *----------------------------------------replaced
  • Faulty spark plug wires or coils *----------------------------------replaced
  • Faulty fuel injector----------------------------------------------------replaced
  • Camshaft sensor defective-----------------------------------------replaced
  • Crankshaft sensor defective-----------------------------------------replaced
  • Engine timing off----------------------------------------------------------checked
  • Leaking head gasket-------------------------------------------------did leak down test OK
  • Low engine compression-------------------------------------------did compression test OK
  • Poor quality fuel ------------------------------------------Ran several cans of fuel cleaner through it
  • Vacuum leak-------------------------------------------------checked
  • Low fuel pressure checked all of these----------------checked still miss fire on 1,5
Old Jan 19, 2022 | 09:40 AM
P0302 is misfire on cylinder 2. Are you getting other codes as well?
Old Jan 19, 2022 | 09:41 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
That awkward moment no one knows what you're talking about because you neglected to include ANY info on just WHAT (year, engine) you're hoping to get us to help you fix.
Old Jan 19, 2022 | 12:01 PM
Laurent1963
No It was then I replaced the injectors that one cleared
Old Jan 19, 2022 | 12:03 PM
Laurent1963
Old Jan 20, 2022 | 09:04 AM
So what codes are you getting now?
Old Jan 20, 2022 | 09:25 AM
Laurent1963
Code 302 misfire on 1 & 5
Old Jan 20, 2022 | 10:15 PM
No. Code P0302 is misfire on cylinder two. If you also have P0301, and P0305, that's an entirely different story.
Old Jan 22, 2022 | 10:21 AM
Laurent1963
It is showing p301, p303, p305 and now p219a and that one is a new code
Old Jan 22, 2022 | 10:34 AM
P0230 Fuel pump primary circuit.
P0303 misfire on cylinder 3
P0035 turbocharger bypass valve...... Which I am thinkin' you don't have. Typo?
P0219 engine overspeed. Basically, revving past redline.
Are those correct? (I suspect the P0035 is supposed to be a P0305, misfire on #5?)
