Sponsored by:
Sponsored by: CARiD
very low dyno numbers
Old Apr 25, 2024 | 03:25 PM
JAYHALL04's Avatar
JAYHALL04
Unhappy very low dyno numbers
i have a 2014 dodge charger RT max and my current mod list is E85(Eflex fuel kit). BBK Long tube headers, cold air intake and a perfomance tune by HP tuners and i recently went to get a few dyno pulls to see where my power is at i ran 305 and 304 WHP. Ive researched stock dyno pulls and have seen up to 340 whp, i am basically running less than stock numbers and im so confused as to why. the car does have 165 thousand miles but i dont believe that is the reasoning to why i would be running those low numbers with the mods i have high mileage or not.
This was on a DynoJet. Thank you for the responses.
Old Apr 25, 2024 | 03:58 PM
Figure in 25-30% powertrain loss, (toward the high end if you are AWD) and your numbers look a LOT better. Also, with that high of mileage, think I would be doing a compression test, followed by a cylinder leakdown test, to see what kind of shape the engine is in internally.
Old Apr 25, 2024 | 04:00 PM
JAYHALL04's Avatar
JAYHALL04
Default Dyno
So I got that dyno a couple months ago and now I have a lifter tick so I am going to upgrade the cam with lifters, not sure if the issue was major around that time which could’ve affected it, The car is RWD
Old Apr 25, 2024 | 04:19 PM
I would consider doing the leakdown test before throwing a cam at it.
Old Apr 25, 2024 | 04:45 PM
JAYHALL04's Avatar
JAYHALL04
What would happen if i did the cam and it ahppened to be leaking? Can whatever the test shows me be fixed afterwards?
Old Apr 25, 2024 | 04:55 PM
Leakdown test tells you what kind of shape your cylinders/valves are in. If there is leakage, the gauges will show how much, and you will be able to HEAR where it is going. Supposedly, up to 25% leakdown is 'acceptable'..... I start thinking about a rebuild at 15%, if I hear it mostly around the rings. Compression test will give you a general idea of cylinder condition. Leakdown will give you DETAILED reading.
Old Apr 25, 2024 | 05:20 PM
JAYHALL04's Avatar
JAYHALL04
But what was the reason you said "BEFORE" i cam it? Can i not fix that issue afterwards?
Old Apr 25, 2024 | 08:17 PM
Gotta pull the heads to do the cam, right? If your compression numbers are bad, no point tearing it down twice. It'll also tell you if you need to get a valve job on the heads while they are off. (which, given your mileage, really wouldn't hurt anyway.)
Old Apr 26, 2024 | 10:29 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Because if you have a problem, that needs to be fixed/addressed BEFORE you throw speed parts at it.
Old Apr 27, 2024 | 05:33 AM
Moparite's Avatar
Moparite
I think you should have had a base line dyno run to see where your starting point is. Are you aware of the issues with MDS? https://www.motortrend.com/how-to/ch...i-mds-lifters/
