Sponsored by:
Sponsored by: CARiD
ALL HANDS ON DECK ESP IS DEAD
Old Nov 8, 2006 | 05:57 PM
  #41
74scamp's Avatar
74scamp
Default RE: ALL HANDS ON DECK ESP IS DEAD
Wowzers! That's a nice switch. Looks like you could mount that almost anywhere and it would look like it belongs. Where did you find it? Just a simple "push button"?
Will you use a grommet in the bottom where you drill the hole for the wire to come through?
dave
Old Nov 9, 2006 | 12:08 AM
  #42
baldyloxs's Avatar
baldyloxs
Got it at Wal-Mart it has blue led in it but I am not wiring it for the light to work $4.00.If I was going through the fire wall I would use a grommet.I'm just gonna tape this up since its plastic. I would be happy to get you one if you cant find one just send me your info via email and 4bucks through paypal.For the 2 that have done it is that 2nd gear BooooooooGGGGG all gone now? thanks
Marty
Old Nov 9, 2006 | 03:09 AM
  #43
karleysDAD's Avatar
karleysDAD
Radio shack has the same switch. Bought minz one today. will do the work this weekend. I have been putting off waiting for some bad post, none came so she goes in this weekend.
If any one is interested, post on Chargerforums.com/ under mod's forums.
RTjunkie's version of the ESP Mod! Writeup!
This has to be the best post for do it your self job. Photos and step by step. great job check it out makes the job so easy. take care. Mike
Old Nov 9, 2006 | 03:58 AM
  #44
topbanna3767's Avatar
topbanna3767
KARLEYSDAD WHAT ARE YOU IMPLYING I SENSE SOME UNDERLYING SARCASIM?
Old Nov 9, 2006 | 01:43 PM
  #45
74scamp's Avatar
74scamp
Thanks, Marty. I'll look - I'll bet I can find something at least similar - although this is New Mexico and things take a little bit longer to get here than other places .
This mod seems like it might be the one we've been looking for. I would suggest that, if after several of us have done it and everything seems to be working fine, that we get it posted permanently on here someplace for future reference by others.
What do you guys think?
dave
  #46
74scamp's Avatar
74scamp
dave
Old Nov 9, 2006 | 02:31 PM
  #47
MangoInTX's Avatar
MangoInTX
Charger Moderator
I'm running to a local electronics place "Altex" at lunch to get some new switches. It's a great place to get stuff, they carry complete computer systems down to circuit boards & resistors. I'm sure they'll have something to fit the bill.
I plan to install this and if it works (I'm sure it will) I'll pull out the GSM wiring that runs through, across the front and up to the fuse box up front. It's a much cleaner suloution. This will also give me a chance to replace the cheap GSM switchs and mount them (ESP and Fan switchs) by the Trunk button.
Here another place to browse for rocker switches, I'm looking for one like the "SPST ROUND ROCKER SWITCH CAT# RS-144" from All Electronics Corp It looks alot like baldyloxs's.
Anyhew... Yes I agree Dave, this should be added to the DIY section.
Old Nov 9, 2006 | 03:16 PM
  #48
karleysDAD's Avatar
karleysDAD
topbanna3767 I am sorry but that is not the way I ment for that to be taken. Just trying to give some advice. and refer other's to another forum that really helped me. Sorry didnt meant to step on any ones toes. Any ways take care. Mike
Old Nov 9, 2006 | 03:57 PM
  #49
baldyloxs's Avatar
baldyloxs
Sounds good Dave.Lets clarify A few things I didt it, you have to remove the ashtray unit to get the last 2 screws took me half an hour to find them.(Just grab on the underside and hold above give firm steady tug comes right out).There are 2 purple wires both have blue stripes on them,one dark one light.YOU WANT THE LIGHT BLUE STRIPE.Ok now as far as mounting I put my switch oppisite side of the acc. port in the center console down low.If you want a pic I would be happy to post one 4 you.If you use a switch like mine test how it flips after you install it,the tighter the fit the harder it flips on/off.Very easy to do I didnt have to disconnect battery cable to do it either.Is it worth it ? Maybe if I was a drifter,or had about 60hp more,or liked doin doughnuts.What noticed was you dont get that second gear power loss,and in no means will it FRY THE TIRES(Unless you hold the brake or run it through the water box)I guess in the end I can look at HAL and say FU
Old Nov 9, 2006 | 04:00 PM
  #50
baldyloxs's Avatar
baldyloxs
and dave you dbl posted up there lol
