Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Fog Light bulb listed doesn't exist
Old Dec 29, 2010 | 09:26 PM
First SUV's Avatar
First SUV
Unhappy Fog Light bulb listed doesn't exist
My owners manual says the fog light bulb is a "PSX24W" but no source of light bulbs list such a lamp. Sylvania cross reference says the fog light bulb is a 2504 which also doesn't exist even at Osram Sylvania.
So what is the correct lamp part number for the 2010 Journey?
TIA
Old Dec 29, 2010 | 10:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
Here is the Mopar part number right out of star parts, L000P SX24W.
Old Dec 29, 2010 | 10:34 PM
First SUV's Avatar
First SUV
Can't find any such part or lamp by that number. Guess I will just have to take the bulb out and look to see what it is.
Old Dec 30, 2010 | 08:03 AM
HammerZ71's Avatar
HammerZ71
I believe 2504 is the harness number, it should be an H10 bulb, Silvania part # 9145.
Old Dec 30, 2010 | 06:33 PM
First SUV's Avatar
First SUV
Angry
So crawled under the car and removed panels till iwas able to get to the Fog Light base. It took a while to figure out how it came out. Release clips on either side and pull.
Still don't know what the bulb is, but it is obvious that the UNIT is a DODGE ONLY part. It is a 24 watt, 12 volt unit. The part number is for the assembly. The bulb cannot be replaced in the assembly. So getting a usable amount of light to fulfill the fog/driving light function is impossible.
I hope the photos come out OK. I have not tried to upload any to this forum before now.
Attached Thumbnails Fog Light bulb listed doesn't exist-fog-light-unit.jpg   Fog Light bulb listed doesn't exist-fog-light-part-num.jpg   Fog Light bulb listed doesn't exist-fog-light-base.jpg
Old Jan 17, 2011 | 10:50 AM
RaiderJay6's Avatar
RaiderJay6
That sucks! I was hoping to throw is some HID's in there.
Old Jan 19, 2011 | 03:19 PM
First SUV's Avatar
First SUV
Default It Truely Sucks
Something as cheap and simple as a light bulb, that will burn out, should not be recreated as to make it totally unique to one car or manufacturer. I am afraid to see how much Dodge wants for a replacement.
It shouldn't require too much modification to the mounting for the lamp to change it to an aftermarket unit that will take a normal hi intensity/halogen bulb.
I will investigate the possibilities when the weather warms up.
I did put a set of HID's in for the low beams. 6000K is s good color/temp. The problem Dodge's have with HID's is that they flicker and can go out intermittently. I found a 6 ohm 50 watt resister across the lead from headlight switch to relay (recommended) coil input. The light flicker a bit when first turned on, but that quits once the resister gets hot. So far, 30 days, I am loving them.
Old Jan 19, 2011 | 03:32 PM
dakota_raven's Avatar
dakota_raven
I just read on JKforums that someone had the same problem and found out that the replacement is H16. The # PSX24W is a chinese bulb number!
Here is the thread!!
http://www.jk-forum.com/showthread.p...X24W)-not-9145
Old Jan 19, 2011 | 10:38 PM
master tech
JK body is the jeep wrangler, JC body is the journey.
Old Mar 17, 2011 | 12:24 PM
EXTREMESRT8's Avatar
EXTREMESRT8
Don't know if anyone found out but a replacement for the 2504 is the 5202
