Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2009 Dodge Journey Brake Light help!!!????
Old 03-23-2011, 05:54 PM
Allipole340's Avatar
Allipole340
Allipole340 is offline
Default 2009 Dodge Journey Brake Light help!!!????
I have a 09 journey and all the bulbs are good and the park lights all come on.But when i press the brakes the lights wont come on.The only one that comes on is the small light on the little spoiler. I checked the fuse diagram but i cant find the brake light fuse location.Does anyone know where the fuse for it located? i checked all the fuses for the park lights m17 and m18 and there good.
Old 08-14-2011, 05:52 PM
Jaykel2's Avatar
Jaykel2
Jaykel2 is offline
Was this ever fixed? I have the same problem with my 2009 Dodge Journey SXT
Old 10-16-2014, 06:29 AM
CraigN's Avatar
CraigN
CraigN is offline
Did you eventually find the fault? I have the exact same problem on my 2010 Dodge Journey RT
Old 10-16-2014, 09:42 PM
jkeaton is offline
Dodge Forum Administrator
Remove the bulbs and clean the contacts real good.
Old 10-17-2014, 06:07 AM
CraigN's Avatar
CraigN
CraigN is offline
Its not a matter of dirty contacts because all the parklights come on and all the fuses for the lights a fine, even the brake switch fuse is ok. I am thinking it is the brake switch itself but how would that explain the little spoiler brake light still coming on.
Old 10-17-2014, 07:32 AM
jkeaton is offline
It is a dual filament bulb. There are separate contacts for the park lights and brake lights in the same socket and on the same bulb. Our 09 did the same thing. It was a contact on one of the bulbs that somehow bent to the side and was not making contact. The park lights worked fine, just no brake light. Just another place to look.
Old 10-20-2014, 03:18 AM
CraigN's Avatar
CraigN
CraigN is offline
I've checked the contacts, its not them, also it wouldn't explain why both would not work at the same time, i am going to have to take it to an auto electrician afterall, hope it will be just a small problem.
Old 10-20-2014, 09:37 AM
jkeaton is offline
OK. Good luck. Report back what you find.
Old 10-20-2014, 01:40 PM
bigtsr's Avatar
bigtsr
bigtsr is offline
I would suggest that those lights use a common ground
for the 2 of them while the 3rd uses ground thru tailgate.
Check the wire loom to the tailgate and/or put in another
ground line for the lights that don't come on.
Most systems keep constant voltage to lamps and switch
ground legs off/on.
Old 04-20-2019, 05:47 PM
Charliecece's Avatar
Charliecece
Charliecece is offline
Default Require help
Hi. I am having the same brake light problem as youention. What was the issue and how can I fix it?
Thank-you!
Charlie
Quick Reply: 2009 Dodge Journey Brake Light help!!!????
