Horsepower Question
Old Nov 5, 2004 | 02:49 PM
  #21
lblackneon's Avatar
lblackneon
Default RE: Horsepower Question
What's the benefit of getting the gaskets and roller rockers?
Old Nov 5, 2004 | 05:45 PM
  #22
Cr@zy Squ33's Avatar
Cr@zy Squ33
ORIGINAL: lblackneon
What do you think of titanium retainers for the valve springs? Is that an improvement or just a way to spend more money?
If I get the cam, will cam gears help a lot to improve performance?
You aren't going ot need retainers unless the ones you'[ve got are really worn and or broken. Retainers are pretty much a waste of money.
Old Nov 5, 2004 | 07:02 PM
  #23
casper's Avatar
casper
your gonna need the gaskets, whenever you take the head off you really should replace the gasket. The roller rockers are stronger and better for the cam.
Old Nov 6, 2004 | 07:33 PM
  #24
lblackneon's Avatar
lblackneon
Has anyone ever got an Ultra Performance Bottom end rebuild kit or the top end kit?
Old Nov 6, 2004 | 09:14 PM
  #25
casper's Avatar
casper
I am planning on getting the top-end kit this winter and the bottom end kit when I do the turbo this spring.
Old Nov 6, 2004 | 09:26 PM
  #26
LowSlowNeon's Avatar
LowSlowNeon
Wow lots of people around here are turbo'in next year.
Old Nov 6, 2004 | 09:35 PM
  #27
Cr@zy Squ33
Cause there is no replacement for displacement.
If I had the JackRabbit Motorsports picture you'd understand.
Old Nov 6, 2004 | 09:39 PM
  #28
LowSlowNeon
I know there isn't. I plan on it at some point too. Just probably not next year. Buildup time next year.
Old Nov 7, 2004 | 01:19 AM
  #29
lblackneon's Avatar
lblackneon
Do engine mounts really increase performance mainly in acceleration? Are they worth it?
Old Nov 7, 2004 | 01:37 AM
  #30
Cr@zy Squ33
Yes, they do. They eliminate quite a bit of engine movement which translates into lost torque. With performance mounts it transfers the energy that would've been lost to the engine moving in the bay under load to the wheels.
New mounts will help out a lot.
