SRT4 engine Swap
SRT4 engine Swap
Hi Guys, Im looking for a toy car, I own a mustang already, and I just want another toy car on top of that one, except for better handling. But, I don't want to throw down 22,000 on a brand new SRT4. So here's my question, In any gen, 1rst or 2nd, how easy is it to just throw a new motor in it? I cant imagine that its that much work, and it should bolt directly up correct? any replys are welcome. Thanks
RE: SRT4 engine Swap
I would just try to find a used SRT-4. (Try here: http://www.srtforums.com/forums/forumdisplay.php?f=165)
An SRT-4 swap into a 1st Gen (95-99) Neon will be a chore. You'll have to fab your own engine mounts (they are not the same) and you'll need to use the SRT-4 wiring harness & computer (unless you plan on going with a stand alone EMS). A 2nd Gen (2000+) Neon may be a little easier, as I think it uses the same style engine mounts, however you'll still need the SRT-4 wiring harness and computer.
ORIGINAL: MChat
I can't argue with the lighter 1st Gen. A 1st gen w/ mild weight redux and a stock SRT-4 engine is a high 12 second car on slicks. I've been playing with the idea of dumping my 2.0L "All Motor" engine in favor of an SRT-4 engine in my 1st Gen... and I've done MASSIVE weight redux on it. I wouldn't run the stock turbo tho, probably another GT30 (like what is in my SRT-4) or a bit bigger (GT35) or even smaller (GT28). 400whp and a car that weighs 1800lbs with driver? That's chassis cert territory.
I guess it really all depends on the skills and/or pocket book of the person doing the swap.
Of course if you really want a challenge, you could do a V8 swap into a 1st gen like I'm helping my brother do... We're adding a frame & cage to a 1995 Neon, (Mustang II front suspension, 4 link rear, lengthening the wheelbase about 9") and then dropping in a 440. Stockish for now, but I'm trying to convince my brother to go with a Megasquirt so we can eventually put a turbo on it and shoot for the 8's .
ORIGINAL: MChat
Trending Topics
ORIGINAL: casper
Now that how you do a motor swap!!!!
ORIGINAL: MChat
Hey everyone, I'm fairly new to this site. been here just wasnt a member, it seems like a great place (very knowledgeable ppl) and a bunch of family teaching and learning from each other. thats kool I just have a question that I couldnt find in the posts, ok I'm getting ready to do a srt4 swap into my 1st gen and I have an idea of everything I am going to need to complete the swap the only thing is the engine mounts.. will they have to be fabricated or can they be purchased from somewhere??? and just to doubl check I can still use my trans. with the new engine right? should have the same sensor plugs just cut-n-splice [:@] into the new harness/ well thanx alot any info would be nice
