96 dodge neon 2.0 sohc 5 speed.
Cars all good now no sel lights or anything got some noise from my tranny though looking for a new one or a good used one if you know any. got the o2 pigtail wired in with heat shrink connectors lights been off ever since. what I meant earlier is when I'm driving ill put it in neutral and coast to a stop and my rpms are anywhere from 1000 to 1400 until I completely stop and then it goes back down to the normal 850-950 range.
Symptoms you describe are usually related to the TB sensors, speedo sensor, or vacuum leak. When I say vacuum leak I am not referring to just lines. The manifold gaskets, injector O rings, TB gasket, and so on need to be checked. I use a vacuum smoke tester.
[quote=96BBNeon;2851593]okay ill check the things you mentioned and post back. just wondering do you know where I can find me a good low mileage transmission that wont cost an arm and a leg?
Your best bet is to find a local junkyard to help you there. A lot of them now have links they use to help them find parts that may be in other locations to make it easier.
