Fiance's Neon needs help...
Old 02-20-2006, 12:25 PM
RadarLove's Avatar
RadarLove
RadarLove is offline
Default RE: Fiance's Neon needs help...
Out of curiosity, what is CPS? Not a term I'm familiar with in reference to the Neon...
With the plugs, make sure you go with basic copper plugs gapped properly (Bosch coppers and NGK coppers/V-powers are cheap and reliable). Platinums and distributorless/wasted spark ignitions do not get along. There's a sticky in this forum that deals a little with that. Same goes for plug wires - dealer replacements, Mopar, Crane, MSD, or Magnecor are the only ones I'd trust. You can get an MSD coilpack for about the same price you'd pay for a stocker at the dealer or a parts store, they're all identical units, so just go with whatever's cheapest.
A sticking injector or a sticking valve can also cause a single cylinder misfire. With a bad coilpack, you tend to get a multiple cylinder misfire because two plugs are always fired at the same time. And before hitting the coilpack, try checking the wiring and connector going into the coilpack, a frayed wire or loose connection will do the same thing.
Best of luck!
Old 02-20-2006, 06:29 PM
mpwal099's Avatar
mpwal099
mpwal099 is offline
CPS= crankshaft Position Sensor
Yes b4 I install the new coil pack I am going to be checking all the wires/ connections/ plugs although they are all brand new. Checking for a fouled plug, and giving it a seafoam treatment.
When my coil pack went on my Saturn i had only 1 cylinder misfire and had to replace the whole pack. I was lucky enough to have mine look like sparkler under my hood when it went bad so maybe hers will be like that too. I will find out in about an hour when she finally gets here.
Thanks again guys!
Mike
Old 02-21-2006, 01:48 AM
71RoadRunner's Avatar
71RoadRunner
71RoadRunner is offline
Go with the MSD coil pack, it is far better made than stock with the same output and cheaper, MSD $69.99 vs. stock replacement $85.99. If you want to give it the best spark possible as well as fuel mileage you can get the MSD/NGK bundle pack from Jegs that gives you the MSD coil pack, MSD 8.5 mm Super Conductor plug wires and NGK V-power spark plugs. Here is a direct link to the bundle: http://www.jegs.com/webapp/wcs/store...0923&langId=-1
Quick Reply: Fiance's Neon needs help...
