First mod?
#41
RE: First mod?
ORIGINAL: R0oster31
With the stuff you've done so far the gauges aren't really a must, when you really need them is when you start doing injectors and chips. If the gauges are going to cost you 300 you could just get one of the chips that has the gauges already built in. I know the attitude will show 4 things at a time, you could do EGT, boost, fuel pressure and tranny temp, or just set it to warn you if any of those things go out of limits and look at other things. When I picked mine up I got it for 650, so really you are spending 350 for the chip and 300 for the gauges.
ORIGINAL: Mayfair
I'm kinda doing things bass-ackwards.
I started with the K&N, then the Aero, the Mag-tec pans, the FASS, and NOW I'm starting to think about gauges. I think I'm just going to go with the fuel pressure, egt, and boost gauges. I'm looking at those Isopro ( sp ) gauges. For the whole she-bang it'll be a little over 300 bucks. Sound good?
I'd LOOOOVE to get a set up like Demons ( Cobolts ), however I don't have that kinda cash lying around like he does.
#43
RE: First mod?
ORIGINAL: Super Dave
Does the Attitude monitor fuel pressure and does it come with the sender?
ORIGINAL: R0oster31
ORIGINAL: Mayfair
#44
RE: First mod?
gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges, gauges,
