Pullin the "Gauge Trigger" today ...
Old Jun 27, 2007 | 04:59 PM
  #51
SpLaT's Avatar
SpLaT
Default RE: Pullin the "Gauge Trigger" today ...
Can ya post a pic of your intake manifold, maybe one of us can point ya in the right direction
You should be able to pull the panel out that has the headlight switch on it, to get at the wiring, not sure how to but somebody here ought to be able to help here?? Talk about "rat nest" with all the wiring for gauges and the off road lights plus the all the factory stuff under the dash, I can tell ya.. you called it right... RATS NEST!! [:@]
Make sure ya run that inline fuse between the gauges and yer CB... 5 amp fuse too eh!?
Those manifold bolts are "plugs".. I installed mine as far back as possible less wiring need and cleaner install.
Old Jun 27, 2007 | 06:11 PM
  #52
Drew's Avatar
Drew
donnie. . .I took that pic looking at the very front of the engine. the first intake manifold bolt closest to the engine, just yank that one out and put the boost bolt in, torque to 18-lb-ft and your good to go
Old Jun 27, 2007 | 11:35 PM
  #53
jakebrake's Avatar
jakebrake
How the heck do you guy's reach the headlight switch? My headlight switch is ALLLLL the way up at the top of the dash burried behind one heluva rats nest of wires. Where do you start?
That plastic trim piece that runs all around the dash just pulls off (kinda stubborn), then two torxs(if I remeber correctly)hold the switch in from the front.
Old Jun 27, 2007 | 11:38 PM
  #54
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: jakebrake
, I just had a really long probe from a semi
Does sharx know you are cheating on him?
Old Jun 27, 2007 | 11:44 PM
  #55
Ben D.'s Avatar
Ben D.
That poor guy sharx is just gettin ridden like a donkey on this forum lol. I just hope he doesn't have like a freakout and go postal and drive around the country lookin for us all.
Old Jun 27, 2007 | 11:48 PM
  #56
JimmyDiablo
I guess I would be first since I live 20 minutes from him. better lock the doors.
Old Jun 27, 2007 | 11:53 PM
  #57
Ben D.'s Avatar
Ben D.
lock the doors and put a few pieces of duct tape across ur rear end just in case he doesn't wanna kill ya just violate you.
Old Jun 28, 2007 | 12:25 AM
  #58
JimmyDiablo
I will use sillicone or rubber cement.
Old Jun 28, 2007 | 01:31 AM
  #59
jakebrake's Avatar
jakebrake
It's ok, I shoot back.
Might cause some issues down the road, I'll just carry a can of brakeclean. A little squirt in the right place will take a bear down
Old Jun 28, 2007 | 03:16 AM
  #60
Mayfair's Avatar
Mayfair
ORIGINAL: jakebrake
REALLY ??
You just pull it off ??
I'd be afraid of cracking / breaking it.
The wood grain piece just pops off ??
Is where the boost bolt goes pictured here ??
[IMG]local://upfiles/42139/EB6153AE5048440F910ADB57E58FB2E2.jpg[/IMG]
[IMG]local://upfiles/42139/1E1FA16F5D3A4BA5B9919FED15AF0B19.jpg[/IMG]
