Valve adjustment DIY
Old Aug 2, 2007 | 08:22 PM
  #31
Drew's Avatar
Drew
Default RE: Valve adjustment DIY
ORIGINAL: Methos
ORIGINAL: Drew
ok, it's only when your working with aircraft does it get funny[:'(]
Drew,
This comment confused me a little. Are you just implying that aircraft have less tolerance to a minor variance than autos? Just wondering.
tollerances get MUCH tighter. . .instead of useingft-lb wrenches they use in-lb. we test to 4% accuracy for standard non-aviation wrenches, however aviation wrenches are tested to 2%. the standard we use is acurate to about .005 inch-ounces
and not only that, every screw, nut, and bolt has a torque spec on it for aircraft. Even though a torque spec is listed for our trucks I normaly just use German torque standards, goodentite
Old Aug 2, 2007 | 08:48 PM
  #32
jakebrake's Avatar
jakebrake
Either that or locktite
Old Aug 2, 2007 | 11:07 PM
  #33
CowboyBob's Avatar
CowboyBob
I just did my truck and man was it off. The exhaust valves were worse than the intakes. It is much quieter now.
Old Aug 2, 2007 | 11:45 PM
  #34
steve05ram360's Avatar
steve05ram360
ORIGINAL: CowboyBob
you know, I was just going to ask if anyone has done this yet since the DIY was posted...
Glad to here you went for it Bob... how was it for you? One question I dont recall seeing an answer to is if you do the adjustment hot or cold...?
Old Aug 2, 2007 | 11:53 PM
  #35
Super Dave's Avatar
Super Dave
Cold. It'sin the first post
The manual says under 100 degress. The reason is that the valves and pushrods expand more than the block when it gets hot and the gap will actually close up.
Old Aug 3, 2007 | 11:55 AM
  #36
Mayfair's Avatar
Mayfair
ORIGINAL: CowboyBob
Did you take any pics Bob? I'm curious to see the difference inside in pics between Dave's 3rd gen and your 2nd gen.
Are the gaps the same?
Old Aug 3, 2007 | 04:00 PM
  #37
steve05ram360
ORIGINAL: Super Dave
yup, sorry I missed it. when adjusting the rollers on my 2000 5.9 they wanted it done hot. sucks... many little burn scars on the fingers [:@]
Bob, did you re-use the valve cover gasket? I'd assume you could as long as it's not damaged...
Old Aug 3, 2007 | 07:58 PM
  #38
jakebrake's Avatar
jakebrake
Mayfair, valve lashis the same (just to be safe, check your engine data plate, I should have pics of under the valve cover in my gallery.
Old Aug 3, 2007 | 08:51 PM
  #39
Drew's Avatar
Drew
if I'm not mistaken. . .all 5.9's from all generations are lashed at .010" intake and .020" exhaust.
Old Aug 4, 2007 | 05:15 AM
  #40
cracker's Avatar
cracker
Just a quick question. Do you turn the engine as you are looking at it clockwise or counter, or does it even make a differance?? I was thinking I read somewhere that you can turn it counter by the alternator pulley?? Thanks.
