Woo hoo its here
Old 09-11-2007, 07:16 PM
ga_noplugs's Avatar
ga_noplugs
ga_noplugs is offline
Default Woo hoo its here
Ya'll are a bad influence. After months and months of hearing about performance this and enhancement that, the bug bit me. I broke down and found a nice little TST PowerMax (R49model ) to add to my truck. I figured it was safe (r?) now that I have a full set of gauges...
Unfortunately, I have to wait till the friday to put it in and play. [&o] ..sniff...
Any recommendation from those of ya'll that have one? (Drew, Steve?)
Old 09-11-2007, 07:25 PM
NickBeek's Avatar
NickBeek
NickBeek is offline
Default RE: Woo hoo its here
Double check this but, I thought someone said there are some issues with the TST box and '06 trucks. I'm not sure which box of theirs but one of them.
Old 09-11-2007, 07:33 PM
ga_noplugs's Avatar
ga_noplugs
ORIGINAL: NickBeek
I did check on that . My 06 was actually built in Nov '05. It was the mid '06 06's that started having troubles.
Old 09-11-2007, 07:51 PM
sharx ram's Avatar
sharx ram
sharx ram is offline
These guys are bad about that arent they?
Old 09-11-2007, 08:44 PM
triton's Avatar
triton
triton is offline
I'm not sure of any mods you have but, you have to be careful about draining your rail with the TST. It likes to fuel ! I would definitely start on the low settings and work your way up. You may not be able to go too far past 2/2 or 3/3 before you see your rail pressure dropping to far.
Watch the timing too. You probably shouldn't run it too high... 12 degrees is all I ever went and only when looking for power. That will make it smoke a lot too.
Man I wish I was able to use it still. I was luck that it worked period because of my trucks build date but, because of the problems with it I sent it back. I sure hope they get it worked out, it's a killer box !
Old 09-11-2007, 09:23 PM
ga_noplugs's Avatar
ga_noplugs
ORIGINAL: sharx ram
The words pot, kettle, black come to mind...
Triton,
I'm gonna be real careful. I can't afford to play past 4/4 at the moment..
Old 09-11-2007, 11:29 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
I wouldnt go past 3/3 w/o tranny upgrades... as for the rail dropping, I've had mine up to 5/5 with only about a 2k drop in rail pressure (which was turned up too btw)... It's funny I can tell when the fuel filter is overdue... rail pressure drops easily, drop in a new filter and the drop is minimal... night & day.
Old 09-12-2007, 01:23 PM
Silverline's Avatar
Silverline
Silverline is offline
Just ask Mayfair about how bad an influence we all are. He swore he'd never upgrade power and now he's got an Edge. [sm=badbadbad.gif]
Old 09-12-2007, 02:43 PM
Drew's Avatar
Drew
Drew is offline
I run mine on 4/3 on a daily basis and still average in the 18's for fuel mileage. but then again the stick can handle the increased power a little better than the auto.
my TST is great, however, below 1500rpm it lacks the punch you get when you have the rpm's at say. . .2K.(slipping the clutch usualy solves that problem)
Old 09-12-2007, 10:03 PM
steve05ram360
Hey Drew... upgrade your box and you'll have the rail pressure adjustment which will fix the low end as much as you want. I run mine on 1 for the most part, 2 & 3 are fun.
