Annoying Squeal
Old 09-16-2007, 04:35 PM
04QC4X4's Avatar
04QC4X4
04QC4X4 is offline
Default Annoying Squeal
I have noticed a high pitched sqealing coming from somewhere in the front of my truck. I thought it was the brake pad wear tabs so I replaced the pads. They were not worn enough for the tabs to cause the noise. It is still squealing and getting worse every time I drive. It first started only when I was going above about 50 mph and it was very faint. Now it is at all speeds and gets pretty annoying at high speeds. I really have no idea what it could be. Anyone have any ideas?
Old 09-16-2007, 04:50 PM
Drew's Avatar
Drew
Drew is offline
Default RE: Annoying Squeal
could be a wheel bearing. . .you can change out the whole assembly, or knock out the bearings and repack them. there is a how to in the FAQ thread at the top from lesimon
Old 09-16-2007, 05:00 PM
07 Ram TRX4's Avatar
07 Ram TRX4
07 Ram TRX4 is offline
Could get a can of Brake Cleaner and spray everything that moves..... Could just be dust........
Old 09-16-2007, 05:43 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
take a hose and rinse the front wheels off and spray the calipers, or remove the wheels and use brake kleen on the calipers and disks.
if ya use water, let it drip dry before drivin far.
it only squeels during drive time?
Old 09-16-2007, 08:57 PM
04QC4X4's Avatar
04QC4X4
04QC4X4 is offline
Yes. The sqealing doesn't change when the brakes are applied. I'll try cleaning and see if it helps. Thanks for the advice.
Old 09-16-2007, 09:22 PM
04QC4X4's Avatar
04QC4X4
04QC4X4 is offline
I went ahead and sprayed it down with water hose. I'll let you know tomorrow if it helped. Thanks again.
Old 09-17-2007, 12:26 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
ORIGINAL: 04QC4X4
thats cheaper than parts swappin!!!
other wise lube the whole front end and u joints well. if its a bj or uj then it should not squeek for a while or squeek less anyway.
its really hard to tell wiht out bein there...
Old 09-17-2007, 02:08 AM
Twoforme2's Avatar
Twoforme2
Twoforme2 is offline
ORIGINAL: 04QC4X4
why don't you unlock the door and let the poor gal out...j/k
If it is only when moving you should be able to isolate it, and figure it out, maybe wheel bearing, could the front diff be low on fluid, (although I would think that to be more of a "howling" sound). Is it possible to jack up the front and with the vehicle in neutral, turn the wheel by hand and simulate the sound?
Old 09-17-2007, 11:36 AM
SoNauty's Avatar
SoNauty
SoNauty is offline
have you checked the grill... maybe there's a kid stuck in there!
Old 09-17-2007, 05:39 PM
04QC4X4's Avatar
04QC4X4
04QC4X4 is offline
That's what I thought! If he's up there he's really good at hiding.
Seriously though, I will jack up the front end and see if the squeal is there when I spin the wheels. I don't think its the front differential, but is there a way to check the fluid level. I've been thinking of changing the differential fluid anyways. This might be a good time to do it.
Quick Reply: Annoying Squeal
