Accidential Panic Botton Hit
Old Sep 24, 2007 | 06:48 AM
Bigriver's Avatar
Bigriver
Default Accidential Panic Botton Hit
Hey guys, Been away for awhile, but I've been wondering...........Has anyone had a problem with accidentially hitting the panic button on our ignition keys while turning off the engine. As hard as I try, and when the most Un-oppertune time is present , I accidentially set the damn thing off. Once in the early morning at a KOA campground, or at a resteraunt, and then recently at the deer camp. What a pain this is.....just wondering if this can be de-activated? I'm over the embarassment now, so just fire away.......any comments?
Old Sep 24, 2007 | 08:14 AM
bksram3500's Avatar
bksram3500
Default RE: Accidential Panic Botton Hit
I set mine off by manually unlocking and then opening my doors at 3AM in a motel. then I hit the panic button to turn it off and it didn't work, tried starting the engine and it turned off the alarm from opening the doors but by that time I had the panic button pressed. It took me a while to figure that out.
Old Sep 24, 2007 | 10:16 AM
Twoforme2's Avatar
Twoforme2
Do you have the remote that is built into the key or the one that is seperate from the key?
Old Sep 24, 2007 | 10:35 AM
JimmyDiablo's Avatar
JimmyDiablo
06 and up are built in to the key.
Old Sep 24, 2007 | 11:59 AM
steve05ram360's Avatar
steve05ram360
sounds like a design issue with the key... they should put the panic button on the side or top of the key where it's harder to accidently activate...
Old Sep 24, 2007 | 12:07 PM
cujo's Avatar
cujo
I absolutely hate the damn buttons on the key. I wish Dodge would put them back on a separate fob like before.
Old Sep 24, 2007 | 12:16 PM
Mayfair's Avatar
Mayfair
They put buttons on the key's themselves now? What a PITA !!! Can you still have new keys made, or is that now a "dealer item" as well?
Old Sep 24, 2007 | 12:25 PM
cujo's Avatar
cujo
Dealer item because they have chips in them. 'Bout time we hear from Mayfair again, though you were MIA.
Old Sep 24, 2007 | 12:33 PM
Kev_n_AZ's Avatar
Kev_n_AZ
there is a lock smith here that can order new key fobs. would it be worth a try to order a seperate key fob programmed for your truck??
so its not attached to the key....
Old Sep 24, 2007 | 12:39 PM
cujo's Avatar
cujo
Actually I don't even use the fob. The problem is I don't believe you can get the key with the security chip in it for the ignition minus the fob buttons.
