out of fuel
Old Dec 18, 2007 | 07:07 PM
Methos's Avatar
Methos
Default out of fuel
Well, after 74,000 I finally did it... ran out of fuel on the way to fill up tonight. Only saving grace with it is that I was making the left turn into the pumps when it died so I was able to shove the clutch in and let it coast to the pump. Dang truck is hard to steer without power steering!
Anyway, I know it's not good for these trucks to run out of fuel, but it did fire right back up and ran ok the rest of the way home. Would any damage make itself evident right away or might it take a bit? And, specifically, anything I should watch for in terms of possible troubles?
Last time I ran out of fuel was in 1997.... I guess once every 10 years isn't so bad.
Old Dec 18, 2007 | 08:09 PM
Hauler6's Avatar
Hauler6
Default RE: out of fuel
I dont know how these trucks pickup fuel, but I know in gassers its bad to go under a quarter of a tank because at time (going around corners or uphills) it can starve the pump leading to early demise.
Old Dec 18, 2007 | 10:22 PM
CowboyBob's Avatar
CowboyBob
You should be OK in your 2006. It does not have the VP44 in it.
Old Dec 18, 2007 | 10:48 PM
JR 06's Avatar
JR 06
yeah I see that all the time on the powerstrokes I work on and running them out of fuel does kill the fuel pump, and sometimes a few injectors go with it. so a simple mistake sometimes ends up costing them over $1000 in repairs. i'm not sure if the new 6.4's are like that though since they are HPCR like the third gens.
Old Dec 18, 2007 | 11:00 PM
Drew's Avatar
Drew
you'll be ok. . .the CP3 doesnt have the reputation of dieing when run out of fuel.
Old Dec 19, 2007 | 12:28 PM
Methos's Avatar
Methos
Thanks for the input guys.
I can't believe my luck that was pulling to the pump when it shut down so I didn't have to get out and walk.
Old Dec 19, 2007 | 07:58 PM
CowboyBob's Avatar
CowboyBob
Did I accidentally switch over to the Ford forum???
Old Dec 19, 2007 | 08:32 PM
JR 06's Avatar
JR 06
no sorry, I'm a Powerstroke tech and just giving my input, wasn't sure if it was relevant or not.
